surface for outfeed table
Forum topic by mzimmers posted 02-01-2015 05:19 PM 1400 views 0 times favorited 13 replies Add to Favorites Watch
View mzimmers's profile
193 posts in 3852 days
02-01-2015 05:19 PM
Topic tags/keywords: table surface melamine microdot
Hi, all -
I’m going to build an outfeed table for my table saw. I’ll be following the general steps of the Wood Whisperer’s project.
Can anyone see anything wrong with using Melamine-covered fiberboard for the surface?
I’m kicking around getting some Formica Microdot, but that’ll add about $60 to the project…
-- M. Zimmers
13 replies so far
View ChefHDAN's profile
1023 posts in 2786 days
#1 posted 02-01-2015 05:23 PM
Check out the box store for the laminate they have on the shelves, I can usually get lucky and find a damaged piece the manager will give me 50% or so off on, gets a 4’x8’ sheet of HPL to about $20, and it’s pretty easy to use it for tables wings extensions jigs etc.
Rick Dennington
5746 posts in 3131 days
#2 posted 02-01-2015 06:39 PM
Personally…. I would got with the laminate over Melamine…I don’t like that stuff, cause it will chip pretty easy, and mainly cause it’s underlament is MDF, or fiberboard….My outfeed table for my saws, router table, and anything that requires a slick, smooth finish on top, is laminated…..To me, a laminated top looks nicer (personal preference), and is easy to apply…..But that is just personal preference…...
View lndfilwiz's profile
102 posts in 1537 days
#3 posted 02-01-2015 06:39 PM
Thanks ChefHDAN! I was think about that and have some left over from an earlier project.
-- Smile, it makes people wander what you are up to.
#4 posted 02-02-2015 11:31 PM
Thanks for the input, all. Today I left work a little early to get to a commercial lumber supplier. They said that melamine would probably be OK, and sold me a 5/8” cover sheet for $5. Got a 1/4” one for the workbench for another $5. I figured, even if I go wrong, I can’t go too far wrong.
-- M. Zimmers
View RockyTopScott's profile
1186 posts in 3415 days
#5 posted 02-03-2015 12:24 AM
Mine is currently melamine. I will do laminate the next time.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View TheFridge's profile
9113 posts in 1422 days
#6 posted 02-03-2015 12:33 AM
I think that work fine. Might need a little a little extra support for the 5/8”. Aside from that it sounds like a deal.
2696 posts in 1961 days
#7 posted 02-03-2015 07:35 AM
I notice the chipped melamine every time I walk by them in HD. Have to wonder, if they chip that easily just in being transported and stocked on the shelves, how well are they going to hold up in anything you use them for?
View MinnesotaMarty's profile
126 posts in 1154 days
#8 posted 02-03-2015 01:01 PM
Go laminate, melamine won’t last. Go look for some damaged P-lam at one of the big box stores. Or, check with some solid surface shops and get the old laminate tops that they replace in various kitchens
-- I can see the cheese heads from here and it is great.
4910 posts in 2430 days
#9 posted 02-03-2015 01:11 PM
If you happen to have a Habitat restore nearby, you can usually pick up pieces of damaged laminate for pretty much nothing. I bought a 4’x4’ piece in a very acceptable color for $5. The damage was just a broken corner.
View MaxContent's profile
10 posts in 1159 days
#10 posted 02-03-2015 01:14 PM
I use veneer plywood for a couple of reasons. First, I use the outfeed table as a workbench and it is handy to nail and screw into. Second, I find plastic far too slippery for workbench use. Third, I hate plastic. Wood is a renewable resource.
View Gene Howe's profile
Gene Howe
10267 posts in 3365 days
#11 posted 02-03-2015 01:24 PM
I have 3 melamine wear surfaces. When I get around to replacing them, They’ll definitely be laminate!
View pmayer's profile
1023 posts in 3002 days
#12 posted 02-03-2015 02:30 PM
I went with melamine as a “temporary solution” until I could figure out a permanent plan. That was 12 years ago and it has held up extremely well, much to my surprise. I don’t use it for anything other than a saw outfeed table, so it hasn’t had a problem with chipping (I’ve probably run 3000 – 4000 board feet across the table by now). I doubt that I will ever move on to a permanent solution at this point, although I agree that laminate would be much better, particularly if you perform other tasks on the surface.
-- PaulMayer,
View jumbojack's profile
1674 posts in 2560 days
#13 posted 02-03-2015 02:51 PM
I too have had melamine as my out feed for a few years. It has held up very well. I used it cause it was free.
