cleaning glue from flux brushes
Forum topic by bhacksaw posted 02-01-2015 03:29 AM 1172 views 0 times favorited 19 replies Add to Favorites Watch
View bhacksaw's profile
bhacksaw
163 posts in 1849 days
02-01-2015 03:29 AM
I’ve noticed many of my favorite vloggers use flux brushes from spreading glue. Are they meant to be disposable or is there an easy way to clean the glue off to make them reusable? I’ve heard of leaving brushes to soak in water, but these flux brushes have metal handles, don’t know if that would be a good idea.
19 replies so far
View DIYaholic's profile
DIYaholic
19623 posts in 2700 days
#1 posted 02-01-2015 03:41 AM
I’ll rinse/clean them under the tap….
I’ll store them in water….
It all depends upon how soon I’ll be reusing it.
Yes they are metal and do rust…. hence the disposable nature of them.
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#2 posted 02-01-2015 03:45 AM
Wash them out before the glue has a chance to harden.. and then dry with a paper towel so they won’t rust. As long as you dry them good, they won’t rust.
View tomd's profile
tomd
2155 posts in 3795 days
#3 posted 02-01-2015 03:55 AM
I drop them in water after use they do rust but I reuse them many times before disposing of them.
-- Tom D
View Ghidrah's profile
Ghidrah
667 posts in 1247 days
#4 posted 02-01-2015 04:56 AM
I use them too, if you’re using Elmer’s, Titebond, white or yellow carpenters water base glue, I mash them in the palm of my hand under really warm tap water. I’ve left brushes in the shop over night, (as long as its cool 50s or colder and hours during the summer) and brought them up sit them in hot hot water for a few mins then do the palm mash they’re good to go.
-- I meant to do that!
View Woodknack's profile (online now)
Woodknack
11777 posts in 2405 days
#5 posted 02-01-2015 05:27 AM
I keep a cup of water handy and drop them in for a couple minutes, swish them around, then shake the water out. I’ve been using the same glue brush for a couple years at least.
View Loren's profile
10476 posts in 3672 days
#6 posted 02-01-2015 05:57 AM
The hairs fall out after awhile. I rinse then out and let them
dry and they last for several uses until the hairs start getting
in joints. It is possible the moisture from use and washing
swells the hair and loosens the grip so maybe squashing the
ferule every now and then would prolong life.
View Gene Howe's profile
Gene Howe
10532 posts in 3453 days
#7 posted 02-01-2015 12:18 PM
HF sells a pkg of 36 for less than $3.00.
I tried soaking them in vinegar. Not good. It does really strange things to the metal.
So, now I rinse mine in water and reuse them. But, if I forget and the glue hardens, it’s no biggie.
4999 posts in 2518 days
#8 posted 02-01-2015 01:02 PM
I also keep a small container of water on hand and just toos the brush in it while I’m clamping. Then (if I remember) I’ll swish it around, and dry it with a paper towel. If I forget, I just do it when I’m ready to start gluing again; if I forget to put it in the water, big deal, pull out another. BTW, I cut the bristles back to about 1/2” or so before I use them. Seems to me to be a little easier to use that way.
bhacksaw
#9 posted 02-01-2015 01:06 PM
Thanks, everybody!
View Roger's profile
Roger
20928 posts in 2829 days
#10 posted 02-01-2015 01:28 PM
I buy em at Harbor Freight, then give them a trim. I’ll just wash em out in a baby jar with water if I’m doing a lot of gluing up at one time. If I should forget to rinse em out, I just throw em in the trash.
View Tennessee's profile
Tennessee
2873 posts in 2539 days
#11 posted 02-01-2015 01:39 PM
Since they are 36 for $2.99 at HF, I just toss them. Tried the rinse thing, got rust and the hairs fall out. I don’t use them for small glueups anyway. Just the large panels, as when I sandwich together two layers of a solidbody guitar, or big planks on large bandsaw jewelry boxes.
View bondogaposis's profile
bondogaposis
4765 posts in 2376 days
#12 posted 02-01-2015 02:29 PM
I can’t recall ever using a brush more than once, I get them at HF and use and chuck. More often then using a glue brush I take thin rips from the table saw and cut them to 8” lengths and use that as disposable glue spreaders.
-- Bondo Gaposis
bondogaposis
#13 posted 02-01-2015 02:54 PM
I can’t recall ever using a brush more than once, I get them at HF and use and chuck. More often than using a glue brush I take thin rips from the table saw and cut them to 8” lengths and use that as disposable glue spreaders.
-- Bondo Gaposis
View Jim Finn's profile
Jim Finn
2657 posts in 2947 days
#14 posted 02-01-2015 10:35 PM
I use an artists brush for this and just keep it in a cup of water. Lasts for 5 years …so far.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
MrUnix
#15 posted 02-01-2015 10:53 PM
For larger stuff, it’s much easier to use an old credit card or some other type of plastic squeegee (like those used to lay down metal HVAC duct tape) to spread it out. Those little brushes are a PITA for large stuff and are better suited for smaller glue ups and getting into nooks and crannies.
