Best Wood Glue?
Forum topic by Emily Whitman posted 224 days ago 1138 views 0 times favorited 26 replies Add to Favorites Watch
View Emily Whitman's profile
Emily Whitman
19 posts in 299 days
224 days ago
What is the best all purpose wood glue to use? Thanks in advance!
-- Thanks- Emily, Washington, www.carbideprocessors.com
View dustmaker's profile
dustmaker
33 posts in 343 days
224 days ago
My preference would be titebond 3. I glued a piece up that had walnut and oak in it that I wanted to steam bend it after I glued it.It would not bend with it being glued up. So that sold me on titebond 3 and I now use it on everything.
-- Dustmaker, Kansas
View shopguryl's profile
shopguryl
39 posts in 229 days
224 days ago
For an all purpose I would use titebond II
Titebond III for special things where moisture is a concern, but generally titebond II is sufficient.
View woodworm's profile
woodworm
8262 posts in 487 days
224 days ago
Titebond II.
-- masrol, kuala lumpur, MY.
View drgoodwood's profile (online now)
drgoodwood
382 posts in 1024 days
224 days ago
There is no single best glue.
It depends on:
  • Type of wood(s) and materials
  • Kinds of joining
  • Environmental conditions
I would use a different glue for each of the following:
  • Mortise and tenon
  • Panel gluing
  • Veneering
  • Mixed substrates, e.g. metal to wood
  • Outdoor usage
  • Stone and shell inlay
  • Historical restoration
-- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower."
20707 posts in 718 days
224 days ago
Titebond II for most general applications.
shopguryl
224 days ago
DRG, that’s why Emily narrowed it down to ”all purpose wood glue
GEEEZE, lol
dennis mitchell
3790 posts in 1210 days
224 days ago
View Gary's profile
Gary
589 posts in 329 days
224 days ago
TB II & TB III like the rest. If you get into specifecs, contact DRG!!
-- Gary, DeKalb Texas
Todd A. Clippinger
5648 posts in 995 days
224 days ago
I use Titebond III as my all purpose. I test my joints regularly and I trust it implicitly.
View johnpoolesc's profile
johnpoolesc
246 posts in 256 days
224 days ago
the one very best.. 70 percent of the time, titebond 2 or 3,,
but if your talking teak, burbinga etc.. gorilla glue
and if your thinking small parts and a quicker bond,, ca
and then at times you can not work without a two part epoxy
drg nailed it,, asking me to work with just one glue would be the same as just one power tool
-- It's not a sickness, i can stop buying tools anytime.
Emily Whitman
224 days ago
Sounds like Titebond 2 or 3 is a good way to go. Thank you so much for all your resoponses. Really appreciate the feedback!
Emily Whitman
224 days ago
I was going to be buying it in bulk, and was hoping to get something that would work well for just about anything. Thanks again everyone. Really appreciate all your responses.
shopguryl
224 days ago
Are you the purchasing agent for carbide processors??
View motthunter's profile
motthunter
2079 posts in 695 days
224 days ago
I prefer the right glue for the job. Each Titebond has its application and for outdoors, I use foaming glue like Gorilla.
-- making sawdust....
Emily Whitman
224 days ago
No, at least I don’t have control over the credit card. :) One of the other girls does the purchasing, I was just helping out to see wich Glue we should buy. By the way, I noticed you were pretty new. Welcome to Lumberjocks! Great people here always willing to give good advice, but I’m sure you have already noticed.
shopguryl
224 days ago
Thank You Emily, Yep, Still a newbie, I haven’t posted any pics yet. Trying to build up my nerve.
View Brian024's profile
Brian024
57 posts in 296 days
224 days ago
Just switched from Titebond II to Titebond III. Anybody use Gorilla’s wood glue?
View pommy's profile
pommy
960 posts in 587 days
224 days ago
i use epoxy i’m affraid glue if i use is straight forward pva wood glue
-- cut it saw it scrap it
View Kindlingmaker's profile
Kindlingmaker
1475 posts in 422 days
224 days ago
I’m a TB III kind of guy but most yellows are great.
View Moai's profile
Moai
721 posts in 289 days
224 days ago
T i t e b o n d I I I …..the ultimate thing.
-- Francisco Luna, San Francisco Bay Area.
View Gofor's profile
Gofor
109 posts in 683 days
224 days ago
For price and overall use, a PVA glue like Titebond II will give good glue strength, some moisture protection, and has easy clean-up. It will work in almost all furniture applications.
Titebond III is more expensive but is more waterproof, making it good for outdoor use, and areas like kitchen/bar surfaces. It has a slightly longer set time, which makes it good for complex glue-ups.
The polyurethane glues like Gorilla glue, are now showing that they do not hold up well in the longterm, especially in moist areas. In complex assemblies, they are good in that you can apply the glue to one surface, and just wet the other with a spray bottle as you assemble (long assembly time). Downside is that they expand (can be a positive in a loose joint), are hard to clean up, and have a very short shelf life after you open the container.
If wanting a no-creep glue for bent laminations, or a “forever” glue, a two part urethane glue like Howard Marks uses is the best, but expensive.
Realize that many of the old masters pieces are still with us after several centuries, and they were put together with hide glue.
Go.
I am not disparaging Titebond I, Elmers white glue, etc. They are inexpensive, but work quite well for many items that are going to be inside in an air-conditioned home. They do have the advantage that you can use moist heat to “unglue” the pieces at a later date in time, much like hide glue. This can be a good thing if you have ever had to refinish/repair a rocking chair, etc.
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View matt garcia's profile
matt garcia
722 posts in 568 days
224 days ago
I like Titebond III, and the Titebond for dark wood.
-- Matt, Houston Texas
View ChuckV's profile
ChuckV
82 posts in 423 days
224 days ago
Speaking of Titebond III, it is on sale at Rockler for $3.79 for the 8 oz bottle.
-- Chuck - Central Massachusetts
View kcrandy's profile
kcrandy
85 posts in 328 days
224 days ago
I can tell you that Museum restorers use what has been used since ancient Egyptian times: hide glue. And one reason is if it has to be removed, it doesn’t hurt the wood around it. Glues that provide bonds stronger than the material around them, then means that material must be damaged if the gluing has to be undone.
View roman's profile
roman
1121 posts in 789 days
224 days ago
2 votes for “yellow”
View John Gray's profile
John Gray
1753 posts in 781 days
224 days ago
All the Tite-Bonds.
