A box problem
Forum topic by CanadaJeff posted 04-15-2009 02:08 AM 1169 views 0 times favorited 5 replies Add to Favorites Watch
View CanadaJeff's profile
CanadaJeff
207 posts in 3513 days
04-15-2009 02:08 AM
Hi everyone, so I picked up Doug Stowes basic boxes and have started to play around with making jewllery boxes. I just did my first glue up and in doing so realized that the sides of the box didn’t line up quite correctly. the bottom is perfectly flush, however the top (where the lid sits) is a little wonky with some sides of the box slightly higher where the mitres join.
I imagine this is likely not a new problem, but I was wondering what people do to even up the sides. I’m a little hesitant to use power tools, because of potential tear out and the idea that one false move may damage or ruin an almost finished box. Any ideas? My only thoughts at the moment are sand paper and perhaps a smoothing plane.
5 replies so far
View ccpenco's profile
ccpenco
84 posts in 3287 days
#1 posted 04-15-2009 02:16 AM
where abouts in canada do you live? near vancouver?
ccpenco
#2 posted 04-15-2009 02:17 AM
View Rob's profile
Rob
143 posts in 3833 days
#3 posted 04-15-2009 08:43 AM
CJ,
Don’t feel alone. Used to happen to me all the time. I found the best way to even up the 4 sides is to use a smoothing plane. I use an LN No. 4, works a treat. Just wait ‘till you get to the hinges!!
Regards,
Rob
-- http://www.damnfinefurniture.com
TopamaxSurvivor
18189 posts in 3579 days
#4 posted 04-15-2009 09:47 AM
I would do it on my table saw with a fine cut blade going very slow, but if you don’t want power tools, I guess that’s out ;-))
16272 posts in 4122 days
#5 posted 04-15-2009 05:08 PM
I have a low-tech solution that works great for this:
Get a roll of PSA backed coarse sandpaper, and cover a nice flat piece of plywood or mdf with it. About 18” x 18” is a good size, but larger or smaller is okay depending on the size of your box. Then just clamp that down tightly, put the uneven side of your box against the abrasive, and work the box back and forth across the sandpaper.
You’ll find this works more quickly than you’d expect, and it eliminates the problem of taking off too much material at a corner and making your lid fit poorly.
