source for non-pressure treated 4x4 posts
Forum topic by maddawg308 posted 01-30-2015 08:08 PM 28943 views 0 times favorited 18 replies Add to Favorites Watch
View maddawg308's profile
maddawg308
83 posts in 2581 days
01-30-2015 08:08 PM
Have to build some indoor furniture and a couple lofts, for the neighbors kids for when they go off to college later this year. I have found it impossible to locate non-pressure treated 4×4 posts for the projects, and they are needed. And pressure treated would look stupid next to the rest of the lumber, which is regular pine. Probably smell bad too, if used indoors.
Anyone know of a distributor that stocks plain pine non-PT wood in 4×4 dimensional size?
-- Plank says: "If you're a little board, might as well get hammered!"
18 replies so far
View NinjaAssassin's profile
NinjaAssassin
642 posts in 1843 days
#1 posted 01-30-2015 08:14 PM
I’ve been thinking about the same thing, recently. I intend to find some cheap, clear 2x material from one of the big box stores, rip to width and laminate them. Would that serve your purpose?
-- Billy
maddawg308
#2 posted 01-30-2015 09:31 PM
I’d prefer it be solid, otherwise I’d just use 2×4s and screw them together, but that would look like crap and probably won’t be as strong.
View JayT's profile
JayT
5820 posts in 2330 days
#3 posted 01-30-2015 09:45 PM
Check around at some contractor lumber yards (not Home Depot or Lowes) and see if they can order you something. We routinely order in Doug Fir beams in a variety of sizes for customers. Depending on how you are finishing, it could look OK with the pine.
View Rob's profile
Rob
704 posts in 3190 days
#4 posted 01-30-2015 09:53 PM
I haven’t seen non-PT 4×4s anywhere locally. If appearance matters, use glue instead of screws. My dining room table has laminated legs like what Billy suggested, and it looks fine to me but I admit it would look nicer if it were solid. If you don’t want to see the laminations you could miter 4 sides of each leg together. This way the joints will be hidden in the corners. The middle of each leg might be hollow depending on how you cut the parts, but they’ll still be strong. Also, if you start with a single wide board for each leg, you can cut adjacent sides of the leg out of the same board to make the grain wrap nicely around the corners. For example, you could rip 2×8 down the middle then resaw the resulting 2×4s and wrap the grain almost perfectly around 3 of the 4 mitered corners.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View gfadvm's profile
gfadvm
14940 posts in 2809 days
#5 posted 01-31-2015 01:51 AM
Don’t know if you have a sawmill near you but they can cut your 4×4s from any type of lumber. That said, if you joint and glue a pair of 2×4s, you will be hard pressed to tell it’s not a solid 4×4.
18860 posts in 1975 days
#6 posted 01-31-2015 01:59 AM
What Andy said or try a small town lumberyard. Mine was gonna order 6×6 for me from their supplier, but I found a sawmill that cut them. They were gonna get the supplier to send some before they were treated.
#7 posted 01-31-2015 02:00 AM
Look on craigslist under materials for sale.
View richardwootton's profile
richardwootton
1699 posts in 2074 days
#8 posted 01-31-2015 02:01 AM
My Lowes used to carry untreated 4×4 doug fir posts, but they weren’t with the rest of the construction lumber. The were close to the outdoor fencing type materials.
-- Richard, Hot Springs, Ar -- Galoot In Training
View cebfish's profile
cebfish
156 posts in 2807 days
#9 posted 01-31-2015 02:07 AM
lowes in west virginia always in stock
View WDHLT15's profile
WDHLT15
1766 posts in 2595 days
#10 posted 01-31-2015 02:12 AM
Dawg,
You are too far from me, but I cut and dry a few. Takes a good long time to dry a 4×4.
View fuigb's profile
fuigb
506 posts in 3076 days
#11 posted 01-31-2015 02:30 AM
Bought some at Home Depot in Flint MI ten years ago. Haven’t needed any since so I don’t know if they’re still there. Look around the fencing and outdoor material. Or, why not make some by laminating 2×4s.
-- - Crud. Go tell your mother that I need a Band-aid.
View FirehouseWoodworking's profile
717 posts in 3392 days
#12 posted 01-31-2015 02:50 AM
OPTION 1: My first choice would be a local lumber yard. They can order them for you from their distributors. I’ve always been successful going that route.
OPTION 2: If you have a Menards in your area, they do carry some nice douglas fir 4×4s in various lengths.
OPTION 3: You could do a lamination of two 2×6s, then trim them down to square stock.
OPTION 4: Have you thought about using cedar 4×4s? The cedar might complement the look of the pine used in the other parts. Cedar 4×4s are normally available in the lumber or garden departments of the big box stores. They are normally used in cedar fences or deck railing posts, so they are fairly easy to find.
Hope this helps. Good luck in finding your stock.
Cheers!
-- Dave; Lansing, Kansas
View Steve Peterson's profile
Steve Peterson
388 posts in 3201 days
#13 posted 01-31-2015 03:49 AM
The last time I recall seeing any at the big boxes, they were all from the center of the log. They included the pith and would crack as they dried. I believe that the most common would be in the redwood or cedar deck area it that would work for you.
-- Steve
gfadvm
#14 posted 01-31-2015 02:38 PM
Stay away from those with the pith. They will not only split, but will twist and warp BAD.
View Rob's profile
Rob
316 posts in 3105 days
#15 posted 01-31-2015 02:51 PM
I bought a Kiln Dried non PT Douglas Fir 4X4 at Home Depot this past September. I found it in the wood fencing area. Here is a link to what I bought. http://www.homedepot.com/p/Mendocino-4-in-x-4-in-x-8-ft-2-Better-Kiln-Dry-Doug-Fir-Lumber-16714/205329065
