Drilling Counterbore Problem
Forum topic by nd23rin posted 04-14-2009 02:40 PM 1609 views 0 times favorited 11 replies Add to Favorites Watch
View nd23rin's profile
nd23rin
20 posts in 3305 days
04-14-2009 02:40 PM
Hello All-
I am a new woodworker, and have a question about some drilling of 1 inch counterbores drilled 3/4 inch deep into a 2X4 frame. I am using a Dewalt corded drill, it is about 5 years old, and 5.5 amps. When I attempt to counterbore it does not seem to do it with any ease, and begins to make the bit smoke and blacken the hole inside. Is my drill not powerful enough for this task? If not, what type of power drill do I need, 18V?, 14V, corded 10A?
Thanks!
Nick
11 replies so far
View Julian's profile
Julian
880 posts in 3494 days
#1 posted 04-14-2009 02:50 PM
Sounds to me like the bit is dull. What type of drillbit are you using?
-- Julian, Park Forest, IL
View Peter Oxley's profile
Peter Oxley
1426 posts in 3843 days
#2 posted 04-14-2009 02:53 PM
I assume you mean construction lumber when you say 2×4 – like a framing stud, right? Your drill should have plenty of power for that.
You may be turning the drill bit too fast. Try slowing the bit speed down so the bit can dig in. You may also have a dull bit. Is it new?
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View sIKE's profile
sIKE
1271 posts in 3723 days
#3 posted 04-14-2009 03:12 PM
I would guess a dull bit is more than likely.
View Gary's profile
Gary
9327 posts in 3402 days
#4 posted 04-14-2009 03:13 PM
I’m with the others Probably a dull bit. BTW…welcome to LJ’s
nd23rin
#5 posted 04-14-2009 05:06 PM
I dunno, the bit is brand new out of the package…..
nd23rin
#6 posted 04-14-2009 05:19 PM
I used this for the counterbore??? RIDGID 1 Inch Ship Auger Bit-Wood Drilling
View WillyWally's profile
WillyWally
8 posts in 3302 days
#7 posted 04-14-2009 05:32 PM
One of my helpers had the drill going backwards. It burned.
-- Willy Wally's Wood Stuff
View 8iowa's profile
8iowa
1580 posts in 3730 days
#8 posted 04-14-2009 05:46 PM
Your burning of the bit is probably due to too high a speed. Your one inch bit needs to be driven with a lower speed higher torque drill. Your drill does not have enough torque for the job.
View BethMartin's profile
BethMartin
111 posts in 3347 days
#9 posted 04-14-2009 06:12 PM
Use a forstner bit. :)
-- Beth
Julian
#10 posted 04-14-2009 07:25 PM
After rereading your post, I hate to say it, but I think you’re using the drill backwards. I don’t see a corded drill ever having a problem drilling into a 2×4.
You should be using a forstner bit to counterbore.
8iowa
#11 posted 04-14-2009 07:54 PM
You also need to watch your drill speed with larger forstner bist. They burn up very fast.
