PEN FINISHING?
Forum topic by ccpenco posted 04-14-2009 06:27 AM 2319 views 1 time favorited 8 replies Add to Favorites Watch
View ccpenco's profile
ccpenco
84 posts in 3408 days
04-14-2009 06:27 AM
Topic tags/keywords: finishing
Does anyone know any good pen finishes? just a place to share some ideas…..
8 replies so far
View LesB's profile
LesB
1748 posts in 3467 days
#1 posted 04-14-2009 07:43 AM
On wood pens I have used wipe on poly, quick dring shellacs made for lathe finishing such as those made by HUT or Mylands Friction Polish, and super glue (Cyanoacrylate) in the thick formula. For synthetic materials I just sand to 600 or 1200 and burnish; sometimes with a wax.
The poly and super glue seem to be more durable than the shellacs or wax finishes.
-- Les B, Oregon
View epp_dog's profile
epp_dog
58 posts in 3437 days
#2 posted 04-14-2009 04:22 PM
On wood pens I have had good luck after sanding with sanding sealer and friction polish. I have done a few pens with a CA finish. On the acrylics after I micromesh I use automotive white polishing compound and then finish with some automotive car wax. I figure if it is hard enough to hold up to bugs at 50 mph then it should hold up to regular use.
-- David, Florida
View Seer's profile
Seer
306 posts in 3666 days
#3 posted 04-14-2009 06:04 PM
Check out the library at penturners.org they have a couple of videos that are well worth watching on finishing. There are two where they do a CA/BLO boiled linseed oil) finish.
-- www.cabinfevercreations.com
ccpenco
#4 posted 04-15-2009 02:16 AM
http://www.youtube.com/watch?v=sqzXtpzvw0A THis is the process that i’m thinking i’ll use all the time. iT seems to give a good high gloss finish… Has anyone tried this and seen how well it works?
ccpenco
#5 posted 04-16-2009 04:22 AM
it seems good enough
View johnpoolesc's profile
johnpoolesc
246 posts in 3384 days
#6 posted 04-17-2009 02:21 AM
mylands high build friction.. as the name suggest, you can add as many coats as you want.. it dries as you spin and buff.. or eee cut and polish
for very hard wood.. i finish it to 2000 grit or so and use carnuba wax.. just hold the block against the pen..
you can go from 300 to 600 to 12 to 2000 is about 2 minutes.. and yes once you finish one above 1000 grit, you will see why i take the extra step..
-- It's not a sickness, i can stop buying tools anytime.
View Bob, Oregon's profile
Bob, Oregon
93 posts in 3416 days
#7 posted 05-07-2009 04:54 PM
I sand all the way up to 2000, apply a coat of medium CA, sand again (lightly) from about 600 through 2000 and then do 2 or 3 coats of a good friction polish like Mylands. Makes a great high-gloss, durable finish and doesn’t take long at all. Just don’t get your nose involved with the CA. It hasn’t killed me yet or made me any stupider than I already was, but it will definitely clean out you sinuses!
-- 73, Bob
117115 posts in 3601 days
#8 posted 05-07-2009 04:58 PM
The finer you sand it the smaller amount of finish penitrates,so I would say it depends on the wood . But lots of guys like the wipe on poly.
