Converting a junk No 4 into a scrub plane?
« back to Hand Tools forum
Forum topic by mramseyISU posted 01-30-2015 03:23 PM 1087 views 0 times favorited 9 replies Add to Favorites Watch
View mramseyISU's profile
mramseyISU
534 posts in 1574 days
01-30-2015 03:23 PM
Topic tags/keywords: scrub plane
Ok here’s an idea that’s a bit out there. I’d like to get a scrub plane because I’m planning on building a new workbench this spring and using old barn 6×6 timbers as a starting point for the top. So I’m thinking having a scrub plane to start flattening the top would be handy. Now I could go find an old one on ebay, since I haven’t seen one on craigslist within 300 miles after a couple months of looking. Since I’m cheap and don’t want to drop $80-$120 on one it got me thinking. Could you take a cheap crappy home cheapo buck bros No 4 clone and grind a radius on the iron and call it a day? I’ve got one from back when I wouldn’t know a good plane from a ham sandwich and it’s a paper weight right now. So I’m wondering if I could convert it. Am I crazy or am I on to something?
-- Trust me I'm an engineer.
9 replies so far
View jmartel's profile
jmartel
7959 posts in 2179 days
#1 posted 01-30-2015 03:28 PM
There’s been a few people that did that with the cheapo Harbor Freight one. I think you mean to grind a radius onto the blade rather than a bevel. You would probably want to file the mouth wider as well.
mramseyISU
#2 posted 01-30-2015 03:30 PM
Good catch on the bevel… Need more coffee this morning I guess.
jmartel
#3 posted 01-30-2015 03:32 PM
http://www.harborfreight.com/no-33-bench-plane-97544.html
That’s the plane I was referring to.
mramseyISU
#4 posted 01-30-2015 03:35 PM
Here’s what I already have.
http://www.homedepot.com/p/Buck-Bros-9-in-Bench-Plane-120C4/100351888?N=5yc1vZc983
View JayT's profile
JayT
5679 posts in 2240 days
#5 posted 01-30-2015 03:38 PM
Been done many times with vintage #3, 4 & 5 planes that cost even less than a crappy new Buck Bros. Since you’ve got got the BB already, no reason not to convert it to sometthing it may be able to actually do well. For rough work like a scrub/jack/fore plane you don’t need near the precision.
Have you seen this video by Shannon Rogers from a couple years ago? He uses a #5, but IIRC also talks about doing the same with a #4 in the video. He also shows the best method for grinding a camber without burning the steel.
Edit: The first thing I would do the BB is either replace or reshape that god-awful tote into something that might be comfortable to use.
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1243 days
#6 posted 01-30-2015 04:55 PM
Absolutely! Don’t forget that you can order an iron for Stanley, or LN or LV&V planes too, and put a radius on that spare one too. Then it’s a matter of swapping iron when you want to scrub. I know you might want to have two planes around so you don’t have to move the frog when you switch tasks, but it is an option if you want to get the most out of a single plane. This would give you a quality scrub plane at a fraction of the cost.
-- Talent, brilliance, and humility are my virtues.
View jumbojack's profile
jumbojack
1677 posts in 2653 days
#7 posted 01-30-2015 05:03 PM
Stimulus has a video on con getting a HF plane to a scrub plane.
jumbojack
#8 posted 01-30-2015 10:41 PM
NOT Stimulus…... STUMPYNUBS.
View bandit571's profile
bandit571
20267 posts in 2712 days
#9 posted 01-30-2015 10:47 PM
About like this one, from HF
Might have sharpened it twice in the last three years…..
