Half-lap joints
Forum topic by BJODay posted 01-30-2015 03:16 AM 984 views 0 times favorited 3 replies Add to Favorites Watch
View BJODay's profile
BJODay
526 posts in 1941 days
01-30-2015 03:16 AM
Topic tags/keywords: dado band saw
I’m making a glider bench. The plans call for some half-lap joints. The best way to make them would probably be a dado blade on the TS. I did this once and I don’t like it. I’m a chicken. So I was cutting them using a router table. Worked okay but pretty slow. Lots of small passes.
I thought I’d take some of the waste out with the band saw first then finish it on the router table. Well the BS cut it so well that I made the rest using it alone. It cut perfectly and I felt very safe doing it. I like this BS more and more every day.
BJ
3 replies so far
View kiefer's profile
kiefer
5619 posts in 2665 days
#1 posted 01-30-2015 03:46 PM
If you are not comfortable with a tool or process don’t do it .
Cutting with a band saw is a good way to do it but I would do a test glue joint to see how well it glues to make sure because the surface may not be suiteble for a glue joint and may need further work ..
Klaus
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
View jmartel's profile
jmartel
7891 posts in 2148 days
#2 posted 01-30-2015 03:56 PM
When I did the big half-lap joint on my coat tree project, I used the Bandsaw. After I used that, I cleaned up and pared to the line with a chisel. I think you’re on the right track, but may want to clean up the joint before gluing, depending on the surface left behind.
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1212 days
#3 posted 01-30-2015 04:50 PM
If you can cut half lap on the bandsaw and go right to glue you are in business! But I would probably cut the joint shallow and creep up on the fit with a plane, block or shoulder, then finished the shoulder with a chisel to make it nice. I would do this coming off the TS or a router as well.
-- Talent, brilliance, and humility are my virtues.
