dust collector vent outside
Forum topic by Tim_456 posted 04-13-2009 05:38 AM 4005 views 0 times favorited 7 replies Add to Favorites Watch
View Tim_456's profile
Tim_456
170 posts in 3561 days
04-13-2009 05:38 AM
Hello all!
I’m looking to install a dust collector and I’m looking at a 1.5HP model (Steel City or Delta) with a cyclone trash can separator. I see some models with a pleated filter on top, other’s with a bag. Anyway, I’ll have the external cyclone and the one inside the DC so most of the wood should either be in the external can or the lower bag if I understand the way it will work. If that is the case, has anyone tried venting the remaining output outside the house/workshop/garage? If there’s little to no dust left, can it be safely vented outside?
Any thoughts on the pros or cons of this and if anyones done this?
Thanks,
T.
7 replies so far
35111 posts in 4366 days
#1 posted 04-13-2009 05:45 AM
The only problem that I can see with outside venting is the amount of heat or air conditioning that you are dumping outside. A 1000 CFM will empty a shop in a short time.
View fredf's profile
fredf
495 posts in 3675 days
#2 posted 04-13-2009 06:02 AM
as Karson says, and if you have a oil or gas heater in the shop or even a wood or coal stove you could be sucking co into the shop . . .
-- Fred, Springfield, Ma
TopamaxSurvivor
18247 posts in 3641 days
#3 posted 04-13-2009 06:07 AM
Depends on what is in the immediate area. Wood dust is explosive. As we used to say in the fire department, “If it grows, it blows.”
View MyOldGarage's profile
MyOldGarage
93 posts in 3393 days
#4 posted 04-13-2009 11:36 PM
I’m using my Grizzly 1 1/2 HP and put a pleated filter on it . . . empties right back into the garage . . . er . . workshop. It’s finally getting warm enough to work outside, so I cut my cheap Chinese plywood (GRRR!) outside to avoid whatever toxins they glued (sloppily) into it. :D
-- Bradley Miller, Blue Springs, MO - http://myoldgarage.blogspot.com
View Cory's profile
Cory
760 posts in 3385 days
#5 posted 04-14-2009 03:41 AM
Dont’ forget about make-up air, too. If you’re dumping that much air outside you’ll create a negative pressure vacuum in your shop. You’ll pull the air from the house and whereever there are cracks/gaps into the garage…..at least that’s what I think I remember from a physics class in high school ;-)
-- The secret to getting ahead is getting started.
View John's profile
John
173 posts in 3759 days
#6 posted 04-14-2009 04:09 AM
I have a Grizzly 2hp bag dust collector and trash can separator lid. I wish I had saved my money and gone 6 inch ducting with a clearvue cylone. The trash can gets all the chips but the fine dust gets sprayed all over the shop. Do a little reading on this site before you buy.
http://billpentz.com/woodworking/cyclone/index.cfm
You want to buy my Grizzly?
-- Brain the size of a planet and they have me parking cars.
View JimmyC's profile
JimmyC
106 posts in 3367 days
#7 posted 04-14-2009 06:46 AM
Good points and bad points.
- removes heat or a/c from shop
- can cause negative pressure, which wreaks havoc with an ignition flame from a heater, or H/W heater, or flue gas from said items ; also problems with wood stoves as far as exhaust fumes and bringing hot cinders into shop
- can cause noise outside of shop , which will be detrimental to keeping your neighbors happy
- NO bad dust to breathe in, any filter that returns in to your shop will release exremely small particles (worst kind for your health) back into your work area
- no back pressure on your DC sytem, allowing you to use a smaller DC and getting the same removal, also allpws your DC motor to run cooler and use less energy because there’s no strain on it
Realistically, most of us aren’t large professional shops running out DC system all day, it’s used intermittenly and our shops are not sealed op as tight as a gnats a$$, so the removing of heat or a/c and the chance of causing a major negative pressure is pretty slim. So it comes down to whether you have neighbors near your exhaust and whether you like them or not.
I’ve been running my dust outside without negative effects, so good luck in your endeavour.
-- -JimmyC...Clayton,NC- "Just smile and wave boys, smile and wave"
