How alcohol affect furniture?
Forum topic by Bud_3 posted 01-29-2015 08:57 PM 854 views 0 times favorited 6 replies Add to Favorites Watch
View Bud_3's profile
Bud_3
825 posts in 1126 days
01-29-2015 08:57 PM
Topic tags/keywords: question
I have a piece of furniture and I dropped 40 degrees alcohol over it and bleach in the area.I cant tell you what wood varnish was used because its old .It have many emotional implications for me so i don’t want to restore.Can anyone who have experience or have same problems like me, to clean that white spot.Or guide me to a precise reading because i don’t have too much time.To be honest i can’t know where to start.Many thanks!
-- Personality and character of a man is like wood,must polish it to shine...
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1116 days
#1 posted 01-29-2015 11:53 PM
Basically both alcohol and bleach will destroy that area of finish. You can’t clean a finish that has been blotched in this way. You need to refinish.
-- Talent, brilliance, and humility are my virtues.
View ElChe's profile
ElChe
630 posts in 1239 days
#2 posted 01-30-2015 12:45 AM
Take a picture? White stain may be superficial and repairable bit a pic would be helpful.
View gfadvm's profile
gfadvm
14940 posts in 2592 days
#3 posted 01-30-2015 01:04 AM
Probably was finished with shellac so should be able to tint some shellac and redo the bleached spot. 40% alcohol would have no effect on poly or lacquer.
View pjones46's profile
pjones46
1000 posts in 2545 days
#4 posted 01-30-2015 02:11 AM
You should try to determine the finish type. If it is an older piece it could be shellac, but, could be Lacquer. Take a Q-tip or the corner of a rag soaked with denatured alcohol and apply it to a spot on the piece somewhere that will not be noticeable, like the back side of the leg, and see if the finish gets tacky if so then the finish is likely to be shellac, if not try the same procedure with a Q-tip or the corner of a rag soaked with lacquer thinner, if the finish becomes tack to the touch then it is likely Lacquer.
This should give you a better chance of determining which way to go.
-- Respectfully, Paul
Bud_3
#5 posted 01-30-2015 11:10 AM
What will be your advice in both cases?
Bud_3
#6 posted 01-31-2015 09:52 PM
On a closer look i find some scratches so the ultimate solution is refinish.Was shellac indeed.Thanks for your time guys!
