Plywood or boards?
Forum topic by RussellAP posted 01-29-2015 08:26 PM 1020 views 0 times favorited 7 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2408 days
01-29-2015 08:26 PM
The upright part of the shelves in the picture could be boards or plywood.
My question is which is better? It’s not going to have a back, client wants the walls to show through.
It won’t be painted, it’s poplar with a very dark stain.
Should I used boards glued up or plywood. Without a back, my concern is that it might wobble with plywood. I’ll have a permanent shelf in the middle and the top will have that curved piece and it will attach to the lower cabinets.
So what do you think?
7 replies so far
View JesseTutt's profile
JesseTutt
854 posts in 2232 days
#1 posted 01-29-2015 08:32 PM
If you can use a face frame or something to cover the edges of plywood I would go with good quality plywood like Baltic birch.
RussellAP
#2 posted 01-29-2015 08:36 PM
I have to use poplar because the mantle and other woodworking is poplar. I have some 3/4 poplar ply though, should be just as strong as any ply. It will have a face plate.
View agallant's profile
agallant
551 posts in 3008 days
#3 posted 01-29-2015 08:36 PM
Plywood would be better if you can cover the edges. Boards can cup and warp over time.
View OSU55's profile
OSU55
1835 posts in 2111 days
#4 posted 01-29-2015 09:26 PM
one will be as strong and rigid as the other. If either choice will have a face plate, ply will go quicker. Properly finished and in a controlled environment like a house, one is as stable as the other.
Regardless of material, the design will be a bit wobbly w/o a back, unless you will be going to the ceiling like in the pic. If so, tie off the top to studs or ceiling joists. Just a couple of screws.
View AlaskaGuy's profile
AlaskaGuy
4371 posts in 2430 days
#5 posted 01-29-2015 09:30 PM
I can’t think of one good logical reason to take the time to mill and glue up pine board when you can use sheet goods.
You could even use MDF as I did in the project in the picture. Built that 10 years ago and it’s good as new.
It’s basically MDF (comfirmat screw work great on MDF) All edged with hard maple. The raised panel door are MDF with hard maple frames.
View Redoak49's profile
Redoak49
3455 posts in 2110 days
#6 posted 01-29-2015 09:54 PM
I would use plywood.
However, I thought that you posted that you “Cant’t Stand Plywood”.
View ric53's profile
ric53
194 posts in 1641 days
#7 posted 01-29-2015 10:10 PM
Plywood
-- Ric, Mazomanie
