Whats your Thickness?
Forum topic by Cornductor posted 01-29-2015 04:40 AM 1169 views 0 times favorited 12 replies Add to Favorites Watch
View Cornductor's profile
208 posts in 2600 days
01-29-2015 04:40 AM
So I’m normally not on here much but do like to snoop. Here’s my question.
How thick do have your wood when it comes to making boxes. Do you use 1/4, 3/8, 1/2, or the biggy 3/4? Whats the typical thickness if any?
Whats your thoughts.
-- An investment in knowledge pays the best interest. Benjamin Franklin
12 replies so far
View Dark_Lightning's profile
3115 posts in 3042 days
#1 posted 01-29-2015 05:02 AM
Thick as a brick, sometimes…
Depends on what I’m making. I use 1/8” and 1/4” for small boxes like eyeglass cases, and up to 3/4” wood for bookcases and cabinets.
-- Random Orbital Nailer
View knotheadswoodshed's profile
215 posts in 2106 days
#2 posted 01-29-2015 01:44 PM
I make almost all of my boxes 1/2” as it maintains a good sense of proportion through different sized boxes I make.
for example, a 4” x 6” box that is made with 5/8 material just looks too thick and clunky to my eye.
I guess it depends on what kind of boxes you are making though, I make jewelry and valet boxes so proportion is important from an aesthetics point of view.
-- Randy - "I dont make mistakes, I make design change opportunities"
View Jim Finn's profile
Jim Finn
2641 posts in 2855 days
#3 posted 01-29-2015 02:44 PM
I make small boxes, hundreds of them. I use 3/8” cedar. When I make a small trunk (16”x16”x24”) I use 1/2” cedar.
View HornedWoodwork's profile
222 posts in 1148 days
#4 posted 01-29-2015 03:07 PM
I think of the breadbox adage, smaller than a breadbox I’d shoot for 1/2 or less, I like the way 3/8 looks and it still has a little meat for joinery options. 1/4 starts to get pretty delicate, you’ll need a steady handy and some fine saws to work that small. I use it inside of small boxes more than as the case work.
Bigger than a breadbox you should start at 1/2 and got up to 3/4 or maybe 7/8. I’ve made a few things out of full 1 inch before but it tends to look a little beefy at that end, so I prefer beads or chamfers to reduce that edge look a little.
-- Talent, brilliance, and humility are my virtues.
View wseand's profile
2796 posts in 2975 days
#5 posted 01-29-2015 04:39 PM
I have only made a few and it depended on what type of box I was making. If I was going to attempt carving it was 3/4 any other was 1/2. Hope that helps but I am sure there are some box makers on here that could give you a better answer.
I would figure that in the design phase you would make that choice.
View AlaskaGuy's profile
3983 posts in 2243 days
#6 posted 01-29-2015 07:55 PM
There no pat answer. It depends on many factors. I sure wouldn’t use 1’’ thick on a finger ring box and I wouldn’t use 1/4’’ thick on a big box for a blanket chest.
View JesseTutt's profile
854 posts in 2044 days
#7 posted 01-29-2015 08:04 PM
I use 1/2” for most of my boxes. Cabinets are 3/4”.
View ShawnSpencer's profile
81 posts in 1475 days
#8 posted 01-29-2015 08:13 PM
3/8” for most keepsake box type items. 1/4” can be good on pretty small stuff. 1/2” can get kinda chunky for most table top type items but, chunky can be a good look for some things. Best to experiment to find what you like.
-- I know you know...
View gfadvm's profile
14940 posts in 2623 days
#9 posted 01-30-2015 12:56 AM
Most of my boxes are 5/8” stock.
View ElChe's profile
630 posts in 1270 days
#10 posted 01-30-2015 01:18 AM
My problem with less than 1/2” thick is finding decent hinges for hinged boxes. Brusso sells some but darned expensive. Other hinges are flimsy.
View jmartel's profile
7744 posts in 2083 days
#11 posted 01-30-2015 01:21 AM
The boxes I’ve made have been 1/2”, or slightly over for the invisible hinges. Those things suck to install and leave very little wall thickness.
#12 posted 01-30-2015 02:25 AM
Im partial to 3/8 material and tend to shy away from 1/2. I really appreciate the comments as this is great info.
