What should I use to fix balusters to a gate
Forum topic by EdsCustomWoodCrafts posted 01-29-2015 03:56 AM 762 views 0 times favorited 6 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
746 posts in 1250 days
01-29-2015 03:56 AM
I am in the design phase of this deck gate and I am wondering how should I fix the baluster(s) to the gate frame..
Is there any other option other than using a forstner bit to drill a hole into the baluster and screwing it into the frame??
Just wondering if anyone has tried anything different..
Thanks
Ed
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
17558 posts in 1763 days
#1 posted 01-29-2015 04:03 AM
Typically for outdoors with wet and dry and freeze and thaw screws work the best. Are you using the Forstner bit so you can plug it? The other option I see is to mortise and tenon the balusters into the rails of your gate.
EdsCustomWoodCrafts
#2 posted 01-29-2015 04:09 AM
- firefighterontheside
Yes I was thinking of plugging it, Im not proficient at m&t joints…...
Thanks
View ElChe's profile
ElChe
630 posts in 1243 days
#3 posted 01-29-2015 04:41 AM
Pocket screws with those funny plugs might give you a cleaner look?
View NoThanks's profile
NoThanks
798 posts in 1436 days
#4 posted 01-29-2015 05:03 AM
you could do something like this.
-- Because I'm gone, that's why!
#5 posted 01-29-2015 12:10 PM
Hmmmm, I typed a whole thing last night about doing what iwud4u suggested, but where did it go. You can also use dowels and drill into the end of each baluster and into the rails.
View Grandpa's profile
Grandpa
3259 posts in 2582 days
#6 posted 01-31-2015 11:22 PM
You have to think about rain and the wood swelling if you do what Iwud4u suggested. It will probably force it apart when it gets wet and swells. If you do what you pictured in your post and screw it, you need to cut the corner off at a 45 deg angle. Leave a small flat on the ends. I would probably do that. If it is just pressure treated lumber it will twist and curl when it gets wet. It is still yellow pine. The treatment is only for bugs and the like.
