Fabric Bolt Rack 2-sided with casters - ideas/pictures needed
Forum topic by Big_T posted 01-29-2015 03:31 AM 1966 views 0 times favorited 4 replies Add to Favorites Watch
View Big_T's profile
Big_T
119 posts in 1380 days
01-29-2015 03:31 AM
Topic tags/keywords: question tip resource arts and crafts
Hello Everyone, wife is needing more space for her sewing so she’s moving from the 9×9 bedroom and into the family room. She’s requesting a fabric bolt rack that can hold 8 bolts. There’s four big bolts for the standard stuff that weigh about 60 lbs each, and 4 smaller ones for the holidays. It should have casters so she can spin it around for the seasonal fabrics. I tried searching online but only found a tubular steel one w/o casters for $250 shipped, can someone point me in the right direction so I can make it myself?
Here’s the one I found:
http://warehousefabricsinc.com/fabric-racks.html
Simple is best since I am just getting started in wood with a Bosch 4100 CS and Dewalt miter saw
View ChefHDAN's profile
ChefHDAN
1067 posts in 2872 days
#1 posted 01-29-2015 12:15 PM
Hey, Big-T, I wish you were closer to DC, I’ve got a pattern I made for these,
jumpstands and of course it’s never been used again. But I suppose you could make a pair of simmilar “legs” in an A frame style out of plywood and just cut the detents at triangles to hold the bolts with maybe a nylon chair glide nailed into the end to retain the bolt from rolling out. Something like this
Of course you may need to buy a jig saw and a few other tools but that’s what projects for the wife are all about…. of course I can build that for ya sweetheart,,, just gonna need to get a few tool additions.
Big_T
#2 posted 01-29-2015 03:05 PM
Wow that’s a great idea. I have an old jigsaw, so that might help. Since it’s holding 300 lbs should I sandwich several boards together or will just one do the job?
ChefHDAN
#3 posted 01-29-2015 07:18 PM
Id go with two layers of 1/2 to 5/8, ... 3/4 would likely be overkill, but then I also overbuild stuff. Plywood I-beam for the top stretcher and then a torsion box base skinned with 3/8 ply and reinforced in the corners for the casters and you’dbe done…
Big_T
#4 posted 02-05-2015 06:07 PM
Id go with two layers of 1/2 to 5/8, ... 3/4 would likely be overkill, but then I also overbuild stuff. Plywood I-beam for the top stretcher and then a torsion box base skinned with 3/8 ply and reinforced in the corners for the casters and you dbe done…
- ChefHDAN
I have no idea what you’re talking about… I-beam, Torsion box, what ??????
I was thinking to just sandwich a 1” ply with a 2” pine and add a 5th wheel in the middle.
