Rig-A-Mortis (Jig)
Forum topic by Vince posted 1501 days ago 2101 views 0 times favorited 13 replies Add to Favorites Watch
View Vince's profile
Vince
669 posts in 1598 days
1501 days ago
Topic tags/keywords: jig question resource router chisel joining milling
Back in 1992 I attended a wood show at Anaheim Stadium where I saw this Rid-A-mortis jig being demoed. I remember my Father-in-law and me watching this guy cut tendons like they were nothing. We were so impressed we split the cost and bought it. 17 years later I opened the box to check it out and set it up.
Well wouldn’t you know…I can’t remember how it works? I can cut the mortis but the tendon I can only cut square when it should be rounded off like the mortis. That was the beauty of the jig, not having to chisel the mortis to match the tendon. Did any one else buy this jig and can offer me some help?
The company I believe is no longer in business.
Vince
-- Vince
13 replies so far
View cabinetmaster's profile
cabinetmaster
10874 posts in 1727 days
#1 posted 1501 days ago
How about a picture so we can see what it looks like. Maybe we could help. Can;t believe you’ve had it that long and never used it….............LOL
View Sawdust2's profile
Sawdust2
1467 posts in 2257 days
#2 posted 1501 days ago
It takes a long time to build up the courage to make a mortise and tenon.
Or he is so old the memory of it just came back.
View PatentNonsense's profile
PatentNonsense
28 posts in 1535 days
#3 posted 1500 days ago
Is this it?
http://www.woodworkingtips.com/etips/etip032301wb.html
Apparently the name was the Miller Rig-A-Mortise.
Vince
#4 posted 1500 days ago
PatentNonsense,
The router base that came with the kit is just like that which works well to make the mortise.
But the tenon jig is the one I’m having trouble with. I’ll take some pictures of it tomorrow and post them.
-- Vince
View mmax's profile
mmax
131 posts in 1624 days
#5 posted 1500 days ago
The manual came with instructions for building a morise jig and a tenon jig which are used in conjunction with the base. If you PM me with your info I could get you a copy of the manual.
-- Always remember you're unique, just like everyone else
View Tony Z's profile
Tony Z
205 posts in 1959 days
#6 posted 1499 days ago
It’s TENON.
-- Tony, Ohio
View Jim Jakosh's profile
Jim Jakosh
7289 posts in 1274 days
#7 posted 1229 days ago
Have you tried to google rig a mortise to find the instruction?
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
Jim Jakosh
#8 posted 1229 days ago
I googled Rig a mortice and found this note on a blog there:
i beleive i saw the jig he described in an old woodworking book i checked out from the library. it was called a “rig-a-mortise”. it doesn’t seem to be made anymore. you can make it yourself…check out this link: http://www.woodworkingtips.com/etips/etip032301wb.html
This is the same as the note above.
What if you made a jig to put over the end of a board to make the teneon that uses a guide bushing to follow a template of the tenon shape you need. It could clamp on the board and have a guide that sits at 90 degrees to the part with an oval hole in the end.
Vince
#9 posted 1229 days ago
I did google it but could not fine the actual company that makes it. But a guy from another woodworking forum had the same jig and sent me the instruction. Jim you link is basically the same thing. But this jig also makes the tenon which I dont use. I use the floating tenon it’s a lot easier for me.
-- Vince
Jim Jakosh
#10 posted 1229 days ago
How does the floating tenen work- like a dowel going into two pockets?
Vince
#11 posted 1227 days ago
You got it, I saw David Marks on the Woodworks TV show and he tends to use that technique a lot.
-- Vince
View dnrogers's profile
dnrogers
1 post in 455 days
#12 posted 455 days ago
I have found a Rig-A-Mortise II jig. I has a manual and some other instructions. I don’t know if all the parts are there but let me know if you are still interested?
Vince
#13 posted 453 days ago
dnrogers
Thanks for the offer but I did manage to get a copy of the manual. Have you used your jig yet?
-- Vince
