Box joints
« back to Joinery forum
Forum topic by lbtrail posted 01-28-2015 02:56 PM 818 views 0 times favorited 5 replies Add to Favorites Watch
View lbtrail's profile
lbtrail
2 posts in 1249 days
01-28-2015 02:56 PM
I want to build drawers using box joints. My question is can I cut 1/2 & 3/4 stock at the same time like you would do making dovetails.
Thank you
5 replies so far
View bobro's profile
bobro
320 posts in 1309 days
#1 posted 01-28-2015 03:35 PM
If you stand a 3/4 thick board on end and run it over a dado blade or router bit 1/2 up from the table, a 1/2 thick board run over the same blade or bit will fit in to the 3/4 thick board at a right angle as far as the depth of the cut, but it will fall short 1/4 as far as the thickness of the 3/4 board.
So, no. BUT if you cut all your fingers at the depth of the thickest boards, 3/4 in this case, then you can trim the resulting overhanging 1/4 off the thicker board after joining. You just have to make the thicker boards 1/2 (that is, 1/4 + 1/4) longer than the final dimension.
-- Lao Ma: You are so full of anger and hatred. Xena: Everybody's gotta be full of something.
View ADHDan's profile
ADHDan
800 posts in 2107 days
#2 posted 01-28-2015 04:52 PM
Not that bobro has it wrong, but (maybe) to restate it more simply: in a box joint, the fingers need to be at least as long as the thickness of the board they mate with. So, if you cut all of your fingers based on the thickness of your thickest board you will be fine.
-- Dan in Minneapolis, woodworking since 11/11.
View waho6o9's profile
waho6o9
8191 posts in 2576 days
#3 posted 01-28-2015 05:04 PM
lbtrail
#4 posted 01-28-2015 05:55 PM
Thank you all for your info. It helped a lot
bobro
#5 posted 01-28-2015 07:30 PM
- ADHDan
Yes- if you gang the boards, which is a good idea for speed and accuracy, you have to go to the depth of thickest board, which means you’re going to have some overhang to trim off, and you have to compensate beforehand for that, when cutting the boards to length.
By the way, I learned this the hard way when I was a teenager 30 years ago. “Face-palm”. My dad taught me all kinds of basics but then let me make my own mistakes, in order to learn how to think ahead and not just work by rote.
Oh- when you are running the ganged boards over the blade or bit, it’s a good idea to back the stack with a sacrificial board, because it’s possible to get blowout on the edges of the fingers of the last board.
Let’s see…yip, on the mass-produced finger-jointed box my wife got there’s a blowout exactly like I did on my first finger joints.
