Can't find bunk bed hardware??
Forum topic by WeekendWarrior posted 01-27-2015 03:23 PM 2453 views 0 times favorited 8 replies Add to Favorites Watch
View WeekendWarrior's profile
WeekendWarrior
17 posts in 2607 days
01-27-2015 03:23 PM
I’m building a set of bunk beds and need approx. 4” bolts to fasten the top safety rails to the header and footer. I found the bolts I need, however, they’re in the U.K. http://www.strictlybedsandbunks.co.uk/bed-bolts-m8-x-100mm-threaded-pack-of-four
Also, would really like them to be dark in color rather than gold.
After searching the web for 2 hours I’m at a loss. I’m asking you guys to share where you shop for hardware. I usually order everything from Rockler and Amazon but neither have anything like these.
Also, what would you call these? The U.K. website calls these “Bed Bolts”. When I use that term I get more U.K. sites popping up.
Thanks guys!
8 replies so far
View Bill White's profile
Bill White
5148 posts in 4194 days
#1 posted 01-27-2015 03:28 PM
Do they have to be exposed?
Bill
-- bill@magraphics.us
WeekendWarrior
#2 posted 01-27-2015 03:40 PM
Bill,
Maybe they don’t have to be but I’m not sure how else to do it while keeping them easy to breakdown. I’m kinda following the design of another set of bunk beds that used matching rail fasteners and safety rail screws.
Each safety rail will have 2 wooden dowels and a screw coming through the outer endboard to secure it.
How would you do it?
WeekendWarrior
#3 posted 01-27-2015 03:43 PM
Here’s an image of the bunk bed I’m following. You can see (maybe, kind of small) the bed rail bolts and lag bolts have matching heads on them. Where can I buy those?
View SuperCubber's profile
SuperCubber
1047 posts in 2519 days
#4 posted 01-27-2015 06:20 PM
These won’t work?
http://www.rockler.com/surface-mounted-keyhole-bed-rail-brackets
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
WeekendWarrior
#5 posted 01-27-2015 06:51 PM
Thanks SuperCubber, those are great for the bedrails, what I need is something to fasten the safety rails. I think I found what I needed though. I just got back from Menards with some flat head cabinet screws. I’ll use those for the safety rails which will create exposed screw heads (I got black).
To mount the bed rails I’ll need to use concealed mounts to prevent a mismatch of the exposed screw heads with the safety rail screws. Probably these since it’s a bunk bed and I don’t want to take a chance of the top bunk seperating http://www.rockler.com/bed-rail-connection-system
View wbrisett's profile
wbrisett
204 posts in 2583 days
#6 posted 01-27-2015 07:07 PM
SuperCubber
#7 posted 01-27-2015 08:29 PM
That’s a good plan.
WeekendWarrior
#8 posted 01-28-2015 12:33 AM
Thanks for the info guys, I think I have a solution figures out!
