What to buy next?
Forum topic by Rivercitykenb posted 01-27-2015 02:53 PM 874 views 0 times favorited 5 replies Add to Favorites Watch
View Rivercitykenb's profile
25 posts in 1146 days
01-27-2015 02:53 PM
Topic tags/keywords: tip question tablesaw
I am VERY new to woodworking (about 6 months into it) and I have made decent progress I think. I have a question about tool priority I would to pose here.
So, I have around $700 I can use to buy my next tool. I am thinking about getting the best table saw I can within my price range because the one I have now is horrible (the ~$100 skil 10” saw from lowes). However, I recently purchased a festool TS55 track saw, which so far has made up for that. The only problem I have with the track saw is repeating cuts of the same size accurately. I do not have a Planer, but I do have a joiner (although it desperatly needs new blades) I have a miter saw (I built a fancy stand for that, my crown jewel of woodworking so far). I have a dust collector, a shop vac, orbital sander, paint/stain sprayer, router and some other things.
So I guess my question is, Should I get a better table saw? a router table? should I just get the accessories for my TS55 that would make repeating cuts easy? I am stumped and want to make the best decision.
5 replies so far
View knotscott's profile
7933 posts in 3306 days
#1 posted 01-27-2015 03:06 PM
It really depends on how you work and what you build. A good TS is #1 in my shop and is where I’d focus my budget and resources at this stage if you plan to stick with wwing, and use a TS regularly. The usual suspects for decent full size stationary saws < $600 include the Delta 36-725, Ridgid R4512, and Craftsman 21833. Craigslist might offer some gems too. Just one opinion…
The ABCs of Table Saws
View Jake's profile
850 posts in 1561 days
#2 posted 01-27-2015 03:15 PM
As always, as many there are woodworkers there are options. If it was me and I had a Festool tracksaw with the track, I’d go with a Decent bandsaw. If I was working only in my closed off room in our house instead of the basement, I’d invest in a good set of handsaws and a jointer plane.
A router table should be after a good TS and BS if you were asking me.
-- Measure twice, cut once, cut again for good measure.
View OSU55's profile
1563 posts in 1920 days
#3 posted 01-27-2015 03:18 PM
I agree it depends on how you work. A TS is central to what I do. I would add the Bosch 4100 TS to the above list. I think knotscott meant the Delta 35-725 not 6, which would be my pick if I had room. I need collapsing fence rails for a reduced standing footprint. Since you have a tracksaw, you don’t need a big cabinet saw to breakdown sheet ply. I think all these saws fit your budget. Research blade alignment for the Ridgid – don’t believe I would consider it. If you know much about machines, craigslist is great. If you don’t know what you’re looking at, buying used can be a real problem. I highly recommend a TS with an easy to remove/height adjust riving knife.
View joey502's profile
523 posts in 1448 days
#4 posted 01-27-2015 03:26 PM
It depends what your project goals are. That being said I add another vote for a good table saw. The table saw does so many things well. My hybrid saw is used more than any other power tool.
View Lumberpunk's profile
334 posts in 2267 days
#5 posted 01-27-2015 03:33 PM
Take your $700 and get a 2nd hand TS and a 2nd hand planer from Craigslist.
You should be able to get a Rigid TS and a dewalt 735 planer for that if you shop around.
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
