Epoxy filler.
Forum topic by Combo Prof posted 01-26-2015 08:50 PM 805 views 0 times favorited 3 replies Add to Favorites Watch
View Combo Prof's profile
Combo Prof
3507 posts in 1275 days
01-26-2015 08:50 PM
Topic tags/keywords: question finishing epoxy filler
I’ve seen an epoxy filler used by wood turners that looks like a copper vein in the wood.
  1. What is it called and where can I buy it?
  2. Is it a bad idea to smooth a board with a hand-plane if it has an epoxy filled crack?
-- Don K, (Houghton, Michigan .. Soon Holland, Michigan)
3 replies so far
View DIYaholic's profile
DIYaholic
19620 posts in 2673 days
#1 posted 01-26-2015 10:34 PM
The copper vein is copper powder added to two part clear epoxy.
You can use any “powder” you’d like….
brass….
turquoise….
silver….
coffee grounds….
Let your imagination run wild!!!
As I don’t use hand planes (yet)....
I can’t really answer that question, but I don’t see why not. I wouldn’t neccesarily use a “high end” (read: expensive) plane, but a run of the mill one should be fine. I’ve just used sandpaper to smooth epoxy filled knot holes. Others may chime in with a better answer.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2528 days
#2 posted 01-26-2015 10:37 PM
What DIY said – just be careful not to put too much of the colorant in the epoxy.
Epoxy hand planes quite well with a sharp iron.
-- Mark Kornell, Kornell Wood Design
Combo Prof
#3 posted 01-26-2015 11:58 PM
Here’s the motivation for my inquiry. I saw on the workbench smack down a recent bench that had cracked, and I thought epoxy filler.
