Does anyone know the name of this type of hinge?
Forum topic by EdsCustomWoodCrafts posted 01-26-2015 06:56 PM 1390 views 0 times favorited 10 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
766 posts in 1310 days
01-26-2015 06:56 PM
Im working on a project
that I need a solution to, someone recommended this type of hinge and I am looking for more information on it, to see if its my solution….
Thanks Forum
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
10 replies so far
View MakerofSawdust's profile
MakerofSawdust
35 posts in 2583 days
#1 posted 01-26-2015 07:04 PM
Looks like what I would call a gate hinge. You would “hang” a swinging gate on the hinge pin.
-- - Kevin from Cincinnati. All my work is guaranteed: Three minutes or three feet; whichever comes first.
EdsCustomWoodCrafts
#2 posted 01-26-2015 07:09 PM
Hi Kevin,
Thanks for responding.. Im working on a project.. that someone recommended this for…
click the link for the other forum topic as it explains in more detail what Im trying to do….
Thanks..
It is a gate hinge but its a particular gate hinge im looking for the name….
View JayT's profile
JayT
5589 posts in 2178 days
#3 posted 01-26-2015 07:14 PM
Pintle and strap hinge, the pintle is the post that the strap slide onto. Around here, most people just call them lift off hinges. There are a bunch of different configurations available for the pintle, you’d just have to hunt for the right one.
View bobro's profile
bobro
320 posts in 1277 days
#4 posted 01-26-2015 07:15 PM
It’s certainly a kind of gate hinge as MakerofSawdust said, but I don’t know if there’s a more specific name for that exact kind.
Usually when people do some kind “yee olde” look they use an ornate strap hinge, but in the very many old gates and doors I’ve seen, the kind you’ve got pictured is more common. Notice that you can lift off the gate with that hinge.
edit- oh, JayT posted as I was typing
-- Lao Ma: You are so full of anger and hatred. Xena: Everybody's gotta be full of something.
MrUnix
6593 posts in 2165 days
#5 posted 01-26-2015 07:38 PM
Looks like a typical strap hinge.. except for the pintles, which are usually “L” shaped screws that go into the gate post.. only difference is those are surface mounted instead. You can get them at the borg, such as these:
They are galvanized, but you can paint them any color you want.
bobro
#6 posted 01-26-2015 07:52 PM
you can see your kind of hinge in a picture here-
http://www.greydragon.org/trips/Hungary/
these are all over this part of the world
I wouldn’t call it a strap hinge because at least for medival doors, your usual strap hinge is mounted onto a wooden frame within the stone arch, while this particular hinge is usually mortared into the wall, as you can see in the picture in the link.
View redryder's profile
redryder
2393 posts in 3068 days
#7 posted 01-26-2015 08:16 PM
These look like cool hinges.
If different is what your looking for, you may like this place.
They send out fat and free catalogs that are always fun to browse through…...................
-- mike...............
View putty's profile
putty
1184 posts in 1573 days
#8 posted 01-26-2015 08:29 PM
Looks like a gate hinge to me, If you have a tractor supply near you they will have some.
-- Putty
View gfadvm's profile
gfadvm
14940 posts in 2657 days
#9 posted 01-27-2015 01:30 AM
The ones I recommended on the other thread have threads on the pin ( think L shaped lag bolt) rather than a mounting plate. Thus you can attach them to corners or flats on your post.
View jerryminer's profile
jerryminer
916 posts in 1408 days
#10 posted 01-27-2015 07:13 AM
If you Google “pintle hinge” or “shutter hinge” you will find lots of examples and sources
