Forum topic by Dusty56 posted 04-08-2009 11:42 PM 1126 views 0 times favorited 3 replies Add to Favorites Watch
View Dusty56's profile
11819 posts in 3621 days
04-08-2009 11:42 PM
Topic tags/keywords: tip resource
HELLO , I’m not sure if this is posted in the correct place , so bear with me , Site Police . LOL
I went to the W.Springfield MA Woodcraft store today for a bandsaw blade and was introduced to a very nice display of P-C router bits at clearence prices. I guess I can’t post pix here so here are some prices for examples :
Well let me put it to you this way .
I got everything from an eigth inch spiral upcut bit for $4.99 (PC#43820PC)to a stackable slot cutter (PC#43392PC) for $19.99 , PC#43932PC 2” Solid Surface roundover 1/2”shank $19.99 ,1/4”straight cut bit $4.99 , 7/16” SCBit $4.99 ,3/8”SCB w1/2” shank $9.99 , 5/32” Classical Ogee Bit w1/2”shank $9.99 , a 15degree solid surface topmount bowl cutout bit w 1/2” shank for$14.99 , and also a 22 degree bevel laminate trimmer wBearing w1/2” shank for $9.99 . That was only an example…they had a lot more to choose from and even more to unpack yet . I told them I would check in again tomorrow : )
I hope this helps some of you out there : )
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3646 days
#1 posted 07-14-2009 06:53 PM
The sale is probably long over, I hope folks had a chance to take advantage of it.
#2 posted 07-14-2009 08:55 PM
It is still going on until they run out of the bits….also , Rockler has a lot of the same bits on sale for $4.99 this week. : )
View sandhill's profile
2128 posts in 3857 days
#3 posted 07-17-2009 02:21 AM
We need new listings at the Woodworkers list if you dont mind taking the time to do it its free as well.
