Kreg Pocket Hole Jigs
Forum topic by bondogaposis posted 01-26-2015 02:57 PM 1961 views 0 times favorited 23 replies Add to Favorites Watch
View bondogaposis's profile (online now)
bondogaposis
4771 posts in 2380 days
01-26-2015 02:57 PM
Topic tags/keywords: jig question joining
I have been thinking about getting into pocket hole joinery and I am wondering what Kreg jig to get. There seems to be so many. My main focus will be to make face frames for cabinets. I can’t decide between the K4 and the R3. There are quite a few others that I would consider, I am just baffled by all of the choices. Any advice from experienced pocket holers would be appreciated.
-- Bondo Gaposis
23 replies so far
View KDO's profile
KDO
154 posts in 2799 days
#1 posted 01-26-2015 03:04 PM
I recently bought the K4 master kit with extras like the clamp, etc.
I am happy with it.
I am not a pro, but I do know a few who are who use the Kreg a lot and they like them.
Kreg makes good quality stuff and I don’t think you would be disappointed.
I have a friend who bought the HF jig and he wishes he had bought the Kreg.
-- Christian, Husband, Grandpa, Salesman, amateur Woodworker.
View CincyRW's profile
CincyRW
156 posts in 1680 days
#2 posted 01-26-2015 03:05 PM
I have the K4 and I really like it. You can use the K4 like an R3 (portable – clamp on where you need it) but not the other way around. I see the K4 as being more of a “bench tool”. It seems like the advantage of the R3 would be to repair furniture you cant disassemble or drag into you shop. I really dont plan on doing any of that so the K4 is great for me.
I’m right in the middle of making some built in bookshelves for our little home office and using the K4. Its working very well. The pocket holes and the jointery are one of the easier parts of the entire project.
I’d highly recommend also picking up their right angle clamp (a pin on one side fits in the pocket hole you just made and a flat surface grips the perpendicular surface) if you plan on making “boxes” of any sort. This thing is worth its weight in gold and makes assembly pretty easy.
View KDO's profile
KDO
#3 posted 01-26-2015 03:21 PM
I would agree with CincyRW. The right angle clamp is a great add-on.
View RogerM's profile
RogerM
792 posts in 2428 days
#4 posted 01-26-2015 03:38 PM
I have had the Kregg K3 and now use the K5. Both give excellent results but the K5 is a little handier to use. Strongly suggest getting the Sommerfelds Cabinet Maker Router Bit set to go with these if you are getting into making cabinets. See https://www.youtube.com/watch?v=klv0jzWD26w for a good demonstration.
-- Roger M, Aiken, SC
View Troy Cleckler 's profile
Troy Cleckler
385 posts in 1400 days
#5 posted 01-26-2015 03:44 PM
I bought the Master Kit at a wood show when they first hit the general market. It’s closer the the K4 style, I guess. because I bought the master kit they gave me a steele plate with a keyhole for clamp. I’ve put both on work boards that I hang on the wall till I need them and set on the table to use them.
I’ll take some pics tonight and show you my set up. I’ve been using it for about 14 years now and once you get one you’ll find that you’ll use it on most all projects as well as repairs. The kit that I’ve got also has the single guide for hard to get to places, use it a lot too.
-- Troy. - Measure twice, cut once and fill the gaps....
View JayT's profile
JayT
5682 posts in 2240 days
#6 posted 01-26-2015 03:55 PM
R3 is fine for occasional use or for needing portable. If you are going to be using a similar setup repeatedly, I’d recommend the newer K5 over the K4, though either of those two systems would work well.
View waho6o9's profile
waho6o9
8212 posts in 2606 days
#7 posted 01-26-2015 04:02 PM
I like and use this one ^.
Kreg has a new DIY Project Kit with the K3, shelf pin jig, and saw guide
and is 50.00 less than the K4.
Here’s another choice ^, as if you needed another one.
View pintodeluxe's profile
pintodeluxe
5708 posts in 2842 days
#8 posted 01-26-2015 05:06 PM
It depends on how you prefer to drill the holes – horizontally or vertically. If you want your board clamped flat to a workbench, all you need is the Kreg Jr. kit.
If you prefer to have the workpiece on end, get one of the bigger kits.
View ADHDan's profile
ADHDan
800 posts in 2138 days
#9 posted 01-26-2015 05:42 PM
I really like the K4. I made an all-in-one for it – mounted it on top of a box with risers for side support, with a drawer and dividers for various screws, plugs, accessories, etc. I like the stability and convenience/repeatability of the mounted jig, although I did get the kit that comes with a “standalone” drill guide that can be clamped to a board.
-- Dan in Minneapolis, woodworking since 11/11.
View john2005's profile
john2005
1768 posts in 2207 days
#10 posted 01-27-2015 10:18 PM
Not sure which model I have, but I don’t use it much so if you want to borrow it you are welcome to. See what you like/don’t like. Its one of the “Master Kits” but its older, so not as complete.
Its this one
http://thumbs1.ebaystatic.com/d/l225/m/mCDVFLFtPNtdGcbibEopzqA.jpg
-- In theory there is no difference between theory and practice. In practice there is.
View OSU55's profile
OSU55
1705 posts in 2019 days
#11 posted 01-27-2015 10:42 PM
I’ve got the K4 master and the jr, I think – it has one hole. I use the Kreg bit sometimes if going perpendicular – the shoulder provides great clamp strength. The master kit with the bench jig and vacuum attachment is great – very easy to locate for the holes and the vacuum attachment works very well. I highly recommend it if you’re going the pocket hole route. I will say that in hardwoods close to the edge/end, drill a pilot hole – I’ve cracked a few boards (oak) that I didn’t predrill.
View lndfilwiz's profile
lndfilwiz
106 posts in 1630 days
#12 posted 01-27-2015 11:15 PM
Don’t waste your money on the el cheapo models. I bought a cheap one from HD and was not very happy. Ended up getting a K-4 and have been thrilled.
-- Smile, it makes people wander what you are up to.
View MT_Stringer's profile
MT_Stringer
3172 posts in 3260 days
#13 posted 01-27-2015 11:21 PM
I have been thinking about getting into pocket hole joinery and I am wondering what Kreg jig to get. There seems to be so many. My main focus will be to make face frames for cabinets. I can t decide between the K4 and the R3. There are quite a few others that I would consider, I am just baffled by all of the choices. Any advice from experienced pocket holers would be appreciated.
- bondogaposis
I suggest you get the one with the handle on the operator’s side. reaching over or around the cabinet carcases to clamp the workpiece is a pain. I had to get my wife to operate the clamp so I could keep from scraping my arm (I am on blood thinners).
Good luck.
Mike
View Redoak49's profile
Redoak49
3292 posts in 2018 days
#14 posted 01-27-2015 11:25 PM
I have the K4 and used the check out of it making all the cabinets in my shop and other projects.
I recently got the micro pocket guide and have used it to make drawers from 1/2” plywood. You have to be real careful not to over drive the screws.
MT_Stringer
#15 posted 01-27-2015 11:33 PM
