Bee Box Cut Down
Forum topic by wdbutcher71 posted 04-08-2009 04:36 PM 1374 views 0 times favorited 9 replies Add to Favorites Watch
View wdbutcher71's profile
wdbutcher71
36 posts in 3394 days
04-08-2009 04:36 PM
Topic tags/keywords: question bandsaw tablesaw blade
I have been asked a question as a wood worker that I don’t have a good answer for so I figured I would ask the LJ’s.
A friend is an amature bee keeper, who has purchased 50+/- used hives. He wants to cut them down to smaller hives. The problem is that where he needs to cut there is a high likleyhood of hitting 6d nails.
So the question is what would you use to cut down these boxes. We are thinking a TS with the cheapest carbide blade we can find or my band saw with a metal blade. But I am not sure my band saw hase enough throat for the boxes.
Anybody have any bright ideas? Or a blade they have used for a similar prupose with success?
Thanks,
Matt
-- Matthew M. Central Washington
9 replies so far
wdbutcher71
#1 posted 04-08-2009 04:55 PM
bentlyj:
Thought about a sawzall, but their not very accurate.
View John Ormsby's profile
John Ormsby
1283 posts in 3705 days
#2 posted 04-08-2009 05:18 PM
I would try to find someone with a bandsaw that has a large height opening. You could then put on a bi-meta blade that would cut anything.
Another possibility would be to make a guide with stops on it that can be clamped to the box and use a nail cutting skill saw blade. You could then cut one side at a time and just go around the box. Make SURE to use eye protection, a full face mask, and lots of clothing. The sparks from cutting nails can get pretty hot.
I have used saw blades before that cut nails when repairing old floors.
I do not recommend a carbide toothed blade because the carbide will shatter when hitting nails.
-- Oldworld, Fair Oaks, Ca
View Dkol's profile
Dkol
72 posts in 3330 days
#3 posted 04-08-2009 05:21 PM
Sabre saw with bimetal blade and a straight edge guide.
View Waldschrat's profile
Waldschrat
505 posts in 3404 days
#4 posted 04-08-2009 05:23 PM
Wdbutcher71,
I know it sounds labor intensive, but is there no way of pulling out the nails?
How bout a handheld circular saw? (its kind of hard to tell with out a pic, i have to say) perhaps a handheld jigsaw or something….
Dont think a chainsaw would be good, because if yo hit nails, well… its just not good either.
(this may sound like a joke, but…) couldn’t your friend, just take 25 of the beehive boxes and be happy with that?, instead of having 50 small, why not say 25 big ones?
-- Nicholas, Cabinet/Furniture Maker, Blue Hill, Maine
wdbutcher71
#5 posted 04-08-2009 05:52 PM
Waldschrat:
To be honest I don’t know alot about how the boxes are built. Beyond having seen bee hives in and around orchards. What my friend has is 50 hives that are used equipment, some are either damaged on the top or rotting off on the bottom. He is just trying to salvage as many as possible. Thanks for the input.
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3495 days
#6 posted 04-08-2009 07:45 PM
Ok, I will confess here… I use a skill saw, wear eye protection and saw through 16 penny nails, (and a lot of them). Use a cheap blade and not a carbide one, too brittle, but HSS or maybe molyB. I use the HF blades and they actully hold up for a long time and they cheap enough that they can be concidered disposable. Oh course this is not good woodworking practices but sometimes the need far exceeds the proper.
Kindlingmaker
#7 posted 04-08-2009 07:54 PM
Oh, I almost forgot… Go slow!
wdbutcher71
#8 posted 04-08-2009 08:00 PM
Thanks guys, lots of good ideas.
View Toddmc's profile
Toddmc
30 posts in 3337 days
#9 posted 04-08-2009 08:59 PM
I am actually building a bee hive right now for a friend who did not want a full size hive. I am building a langstroth style beehive, and all we did was omit the shallow super (the topmost portion). There is no negitive affect on the colony from doing this other than a smaller hive. I do not know what stlye of beehive your friend has, but if it has multiple sections like most bee hives simple take off the top section (leaving the cover of course).
Here is a good resourse to look at:
http://www.beesource.com/plans/index.htm
