Best finish for a kitchen counter top
Forum topic by Don posted 01-26-2015 12:22 PM 1018 views 0 times favorited 5 replies Add to Favorites Watch
View Don's profile
551 posts in 3174 days
01-26-2015 12:22 PM
Topic tags/keywords: question
Hey folks,
I have been commissioned to build a countertop for a client’s kitchen. The counter top will be around the sink water and over the dishwasher (steam) so I want to use a finish that will make sure this thing lasts a very long time.
Looking for suggestions.
-- -- Don in Ottawa,
5 replies so far
View Bluepine38's profile
3379 posts in 3017 days
#1 posted 01-26-2015 04:25 PM
Not trying to be a smart ass, but what material are you going to use to build it? Corian will not need a finish,
but will need a lot of tools and training. The new expoxy pour finishes are good, but will require some study
and a little practice with small portions before you do a large surface. Wish you lots of luck.
View Charles Maxwell's profile
Charles Maxwell
1098 posts in 3739 days
#2 posted 01-26-2015 04:44 PM
I assume you’re using hardwood in the counter top. I have recently finished a Bamboo counter top and I used a MinWax, two part epoxy varnish. In effect, it’s like putting 30 coats of vanish on your counter with the additional strength and durability of epoxy. I love it. Looks great and even tolerates hot pots being ‘mistakenly’ placed on it. Not too expensive for my 6’ X 2’ counter top. You might consider consulting a local contractor who has more experience. good luck.
-- Max the "night janitor" at
View Don's profile
#3 posted 01-26-2015 04:51 PM
Yes, it will be all hardwoods, mixed flavours.
Thanks guys
View Kelly's profile
1945 posts in 2876 days
#4 posted 01-26-2015 06:42 PM
Whatever you put on it, you want to, also, focus on the underside, several inches in from the sink.
After that, I’d try to thin the hell out of whatever I put on first to get as much penetration of the finish as I could.
In the past, I’ve flood coated and stayed on the process to push as much finish into the wood as I could. To that end, after it quit sucking up material quickly, I kept the bucket of thinned (about sixty percent thinner) finish sitting there and added more every time I walked by.
I let that dry over night, then switched to a 50/50 mix. Then a 25% mix and and final straight coat.
When I did this to a six inch thick piece of cedar, the finish bled all the way through. Essentially, after all the thinner evaporated off, I had a piece of poly wood.
The killer of wood, as we know, is gain and loss of moisture. The more stable you can get the wood, the longer it will hold up. The cedar piece above sat in front of a fireplace, used in the winter, for over thirty years and developed no new splits or cracks. Of course, every side has to be treated to achieve this.
View Clint Searl's profile
Clint Searl
1533 posts in 2293 days
#5 posted 01-26-2015 08:33 PM
Kelly—What you saw that soaked through was just solvent/thinner. The actual finish only penetrates the wood for a couple millimeters. The initial one or two coats sets the limit, as polymerization presents a barrier to greater penetration.
