driving me nuts
Forum topic by Joseph Jossem posted 01-26-2015 04:25 AM 1002 views 0 times favorited 5 replies Add to Favorites Watch
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2509 days
01-26-2015 04:25 AM
Ok quick overview my table saw has a delta fence. the rail if you look length wise installed on saw it has a bow to it. I got a new fence system same one the other day put it on and same bow. I lowered the legs on the extension table still no difference. Seems to work the same and I figure it shouldn’t affect side to side axis.? Its driving me crazy..?? Should I redo it and force it straight?
5 replies so far
MrUnix
7114 posts in 2440 days
#1 posted 01-26-2015 04:28 AM
As long as it’s straight (parallel) to the blade and miter slot, it doesn’t matter if there is a up/down bow to it unless it’s so bad that really thin stock might slip under it. Also, are you sure it’s the fence and not the table? Put a straight edge on it to be sure.
View bigblockyeti's profile
bigblockyeti
5319 posts in 1961 days
#2 posted 01-26-2015 04:40 AM
What model Delta? What model fence?
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#3 posted 01-26-2015 05:27 AM
I have a unisaw retrofitted with an older bies fence. The holes in the extension wings were off on both sides, causing the rail and tube to deflect a bit. I had to waddle the holes out a bit a it worked like a champ. Don’t know if this is the same prob you are having?
Joseph Jossem
#4 posted 01-26-2015 07:00 AM
uni fence its only off about a 1/16 over the length I think its fine im being paranoid.
bigblockyeti
#5 posted 01-26-2015 11:45 AM
Man, I can’t even imagine bending that extruded rail at all. I would think that at only 1/16” you’re probably right about being overly concerned. I would be too though.
