How to Solve Glue up Issues
« back to LumberJocks.com Site Feedback forum
Forum topic by Snoop posted 232 days ago 287 views 0 times favorited 10 replies Add to Favorites Watch
View Snoop's profile
Snoop
19 posts in 306 days
232 days ago
Topic tags/keywords: glue help question tip trick finishing walnut
Hi everybody,
I am building a floor standing mirror for my wife out of Walnut. I have just finished the glue up but have a problem – I didn’t get all of the glue removed from the back and some has smeared across the wood. It is now dried in. What is the best way to remove this? Is there some type of solvent or will a good sanding remove everything so that it will accept the finish nicely? I really value your input as I want this to turn out nicely…especially considering it will be looked at every single day! Thanks.
-- "Whether you think you can, or whether you think you can't, you're right."
20707 posts in 718 days
232 days ago
Snoop, I remove dried glue by a combination of sanding and using a card scraper. It is best if you wait about 30 minutes after gluing up the piece and remove the excess while it is still rubbery with a putty knife. But leaving glue on the piece is a situation that we all face at one time or another.
View matt garcia's profile
matt garcia
722 posts in 568 days
232 days ago
Card scraper, and sandpaper are a winning combination for me also!
-- Matt, Houston Texas
7654 posts in 1114 days
232 days ago
Scrape or sand….take your pick. The bottom line is that once the glue gets into the pores and dries, you’re going to have to remove wood down to the level that the glue has soaked in.
Snoop
232 days ago
Is there something I can do to ensure that I have removed wood down to the level that the glue has soaked in? Wipe mineral spirits on after sanding down to try to identify additional glue spots?
View GaryK's profile
GaryK
9533 posts in 884 days
232 days ago
That about sums it up Charlie!
Snoop
231 days ago
Thanks everybody for your input. I am sure you can see by my questions that I am new at this but obviously want to get better and this forum is a great place to help me do that. Thanks again!
View Moai's profile
Moai
721 posts in 289 days
231 days ago
A sharp chisel used superficially would work. normally those glue trickles don’t penetrate in the wood and pop up with easy.
-- Francisco Luna, San Francisco Bay Area.
Craftsman on the lake
818 posts in 334 days
231 days ago
depends on the glue snoop. If you used white glue (like elmer’s white) then you can sand till doomsday, it will mostly sand the surrounding wood. Scraping is the way to get it off. If you used yellow glue (like yellow titebond) then scraping is the best way but sanding will work on this glue also.
I always use a good scraper to get glue off. It takes it off fast and cleanly.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View juniorjock's profile
juniorjock
790 posts in 661 days
231 days ago
Another vote for the scraper…... boy, Charlie is on a roll…....... good job man.
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
View childress's profile
childress
163 posts in 438 days
231 days ago
You want to use denatured alcohol to check after sanding/scraping. It will show you what the wood will look like with a clear finish and it evaporates quickly.
-- Childress Woodworks
