Routing edge profiles
Forum topic by ajthomas5009 posted 01-26-2015 01:20 AM 728 views 0 times favorited 3 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1525 days
01-26-2015 01:20 AM
Topic tags/keywords: question maple router milling
He all I have a quick question about routing edge profiles. I have some box trays that are already assembled and decided it would be a nice touch to soften the edges by routing a small chamfer on them. Since they are already assembled wouldn’t the router be unable to profile the inside corners? Meaning I would have to finish the inside corners by hand with a file?
Andrew
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
3 replies so far
View firefighterontheside's profile (online now)
17571 posts in 1764 days
#1 posted 01-26-2015 01:23 AM
You can finish the inside with a sharp chisel.
ajthomas5009
#2 posted 01-26-2015 02:49 AM
Ahhh I knew there was a better way than filing. It sound like a chisel is the answer.
#3 posted 01-26-2015 02:54 AM
Just don’t try to take it all off at once as it will likely split off more than you want.
