New guy needs guidance!
Forum topic by nd23rin posted 04-07-2009 04:33 PM 1468 views 0 times favorited 20 replies Add to Favorites Watch
View nd23rin's profile
nd23rin
20 posts in 3205 days
04-07-2009 04:33 PM
Hello All
I am very new to woodworking although I am 30 years old. I have aquired a 3HP Grizzly cabinet saw, Grizzly Jointer, Porter Cable Router (cheaper one), other powert tools…jigsaw, etc. The table saw has a wing that is about 7 feet but no extension table. Does anyone have a good plan to build one easily?
Thanks,
Nick
20 replies so far
View Gary's profile
Gary
9262 posts in 3302 days
#1 posted 04-07-2009 04:36 PM
Welcome aboard Nick. This is a great place. There is probably plans etc for build the extension here on the site but, hold on a few minutes and you’ll likely get lots of responses. Lots of great folks here that are willing to help.
Again, welcome
g
View DaveH's profile
DaveH
400 posts in 3647 days
#2 posted 04-07-2009 04:57 PM
No sure what you are looking to add. Outfeed table? Are you talking about a missing table that fits between the fence rails on a 1023SLX?
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
View Don Newton's profile
Don Newton
714 posts in 3488 days
#3 posted 04-07-2009 05:11 PM
Welcome Nick, If you are talking about the table to the right of the saw between the rails,you can make one that is quite serviceable with a piece of plastic laminate covered particle board. You can also use this area to mount a router.
-- Don, Pittsburgh
nd23rin
#4 posted 04-07-2009 05:12 PM
Yes, initially I need to fill the space on the right side of the table…then I wood need to add out feed. I was wondering, if these could be done in on step.
DaveH
#5 posted 04-07-2009 05:26 PM
I’d build a frame out of 3/4” plywood about 3” tall. Top that with 1/2” or 3/4” plywood and plastic laminate. This needs to be made exactly the same width as the cast iron table. If it is not, you will throw off the fence to saw blade alignment when you bolt it to the rails. I’d pull the rails off the saw to make my measurements.
If you have a tool supplier like Woodcraft, stop in and take a look at some of the extension tables on the display models.
You can probably order a replacement directly from Grizzly.
View Woodchuck1957's profile
Woodchuck1957
944 posts in 3633 days
#6 posted 04-07-2009 09:02 PM
nd23 where are you from ?
nd23rin
#7 posted 04-07-2009 11:38 PM
I am actually toying with the notion of ditching my table saw and jointer for the Eureka zone system. If anyone is interested in the central florida area shoot me an email.
Grizzly G1023S – 72 inch wings
Grizzly 4X6 jointer, stationary model
Both are in excellent condition
Selling both for $800, 550 for the TS, 250 for the Jointer.
Woodchuck1957
#8 posted 04-08-2009 12:03 AM
Go figure.
nd23rin
#9 posted 04-08-2009 12:28 AM
Apoloigies, I am losing my mind today! I am in Lakeland FL, right smack between Tampa and Orlando!
Thanks!
Todd A. Clippinger
8901 posts in 3968 days
#10 posted 04-08-2009 12:35 AM
Just looked at the Eureka zone system – Keep your tools.
View Scott 's profile
Scott
103 posts in 3228 days
#11 posted 04-08-2009 03:07 AM
I agree with Mr. Clippinger. Keep your tools. That cabinet saw will be the workhorse of your shop. When you realize in a year or two that you need it back that same caliber of saw will cost you 2000-3000 to replace!
-- Scott, South Carolina
View Tucker's profile
Tucker
13 posts in 3217 days
#12 posted 04-08-2009 03:31 AM
keep your tools like others have said you will kick your self later if you sell them.
View BlankMan's profile
BlankMan
1490 posts in 3222 days
#13 posted 04-08-2009 03:44 AM
Ditto. Having fallen for gimmicks when I first started woodworking I learned the $$ way so you’d be wise to heed the advice given, that system will never match what you already have.
You mentioned cheap PC router, what model? I wasn’t aware PC made anything cheap…
-- -Curt, Milwaukee, WI
View Pete_Jud's profile
Pete_Jud
424 posts in 3622 days
#14 posted 04-08-2009 04:21 AM
Like most here, The Table saw is the heart of the shop. Keep it, and build the right side insert. The right side insert is easy with cheap materials and will teach you some new skills. 3/4 ply or mdf for the top and some plastic laminate on top using contact cement will be fun, the frame can be just 2×4 stock for a simple frame.
-- Life is to short to own an ugly boat.
nd23rin
#15 posted 04-08-2009 05:15 AM
OK, OK….I hear you! :) Let me explain, up until a month ago I couldn’t even turn on a saw. I gre up in a house where tools were not even present. I did tons of research and read tons of books over the last month or so, but I feel overwhelmed. I have this massive table saw, but no table to really use it the right way. What if it is not perfectly level…..how do I make it so?? Also, I keep hearing table saw horror stories about missing digits, etc! Anyone out there want to offer up some lessons!! HELP
