Kids Toy !! Stop wheel from falling off axel.... How?
« back to Joinery forum
Forum topic by EdsCustomWoodCrafts posted 01-24-2015 08:53 PM 1706 views 0 times favorited 8 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
766 posts in 1313 days
01-24-2015 08:53 PM
So I have decided to try and make a wooden toy for my 2 year old son. Obviously I don’t want small parts coming loose.
I am at the stage of fixing the wheel and axel(Below):-
to the main toy body:-
and I don’t want the wheels to fall off and I don’t want any metal and obviously I need the wheels to stay on the axl..
Does anyone have any suggestions???
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
8 replies so far
View jerryminer's profile
jerryminer
917 posts in 1411 days
#1 posted 01-24-2015 09:13 PM
Glue?
Axle pins:
axle pins
you may be interested in this discussion:
Axle pins vs. dowels
View ElChe's profile
ElChe
630 posts in 1306 days
#2 posted 01-24-2015 09:39 PM
How about taking a larger dowel and drilling a non through hole diameter of axle dowel and gluing it on to form an axle pin?
EdsCustomWoodCrafts
#3 posted 01-24-2015 09:45 PM
- ElChe
That’s a great idea… I have 3/4” dowel and a drill press!!! Disco thanks
View Ron Ford's profile
Ron Ford
208 posts in 1702 days
#4 posted 01-24-2015 10:34 PM
Another option is to drill into the side (tread) of the wheel into the axle with an 1/8” bit then tap in and glue in a piece of 1/8” dowel. Sort of like a wood nail. Sand the edge smooth at the wheel and it will never come off. I’ve made dozens of toys this way without a lost tire.
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
View bigblockyeti's profile
bigblockyeti
5106 posts in 1690 days
#5 posted 01-24-2015 10:57 PM
You could saw a thin kerf in the end of the axle before installing it in the wheel and then do so with a good quality glue (I like polyurethane glue for this type of work), then hammer in a wooden wedge (perpendicular to the wheels’ grain). Much like hanging a hammer or axe head.
View Grandpa's profile
Grandpa
3259 posts in 2645 days
#6 posted 01-25-2015 02:39 AM
I use the method bigblockyeti suggests. Works well and every time
View Tennessee's profile
Tennessee
2862 posts in 2484 days
#7 posted 01-25-2015 02:42 AM
I am where bigblockyeti is at. Thin kerf, glue it into place, the whole axle and wheel assembly turns. The gallery that I show in, there is a guy who builds childrens toys with a lot of wheels, and that is his standard method, cause I looked trying to knock him off. I decided it was too much work and let him have the business, but that is the successful method he uses.
EdsCustomWoodCrafts
#8 posted 01-25-2015 02:59 AM
Well I ended drilling a 3/8” hole in a wooden decorative dowel and glued it to the end of the axl… I must say I wasnt sure what it would look like .. But it looks ok
