Dealing with planer snipe
« back to Joinery forum
Forum topic by texretvet posted 01-24-2015 01:24 AM 1372 views 0 times favorited 9 replies Add to Favorites Watch
View texretvet's profile
texretvet
53 posts in 1250 days
01-24-2015 01:24 AM
Topic tags/keywords: question planer
I have a cheap Ryobi 12 inch planer.
While it seems to work fine in all other aspects, it leaves about an inch of snipe at the beginning and end of each piece unless I precede it with a piece of the same thickness and follow it up with one as well. As I’m sure some of you know this gets really old, really fast.
I extended the in-feed table by 16 inches and the out-feed tables by 24 thinking that would help, but it didn’t.
I have heard some people say that lifting up on a piece as it goes in and as it comes out will help, but it doesn’t seem to on this planer.
I usually just use the method I mentioned above. Or, I just make sure my pieces are longer than what I need, but that is not always possible, and I always feel like I’m wasting wood.
Anyone have any suggestions?
Also, is this just common of all planers? Are there any sub $500 planers that I could upgrade to that wouldn’t have this problem? If not in that price range, what kind of money would I need to spend to move up to something that doesn’t have a problem with snipe?
Thanks ya’ll!
9 replies so far
View TheFridge's profile
TheFridge
9608 posts in 1514 days
#1 posted 01-24-2015 01:31 AM
I’ve heard nothing but great things about the dewalt dw735 13” planer.
I feel your pain. I have an old ryobi AP10.
View Ghidrah's profile
Ghidrah
667 posts in 1250 days
#2 posted 01-24-2015 01:36 AM
1. If you aren’t taking took big a bite out each pass you might see if you can adjust your infeed and outfeed rollers.
2. You might also want to check the knives, maybe they’re a bit too high on the cutter head.
-- I meant to do that!
texretvet
#3 posted 01-24-2015 01:54 AM
Fridge, that’s the exact same planer that I have. HaHa
Ghidrah, I usually take off 1/64 or less on each pass. I don’t get in any hurry!
I seem to get the same amount of snipe no matter how shallow or deep my cuts are. I’m pretty sure the knives are set right in the cutter head. I replaced them not too long ago, and it was the same before and after the change.
I have never adjusted the rollers, but I will look into that for sure.
Thanks!
View Skippy906's profile
Skippy906
121 posts in 2015 days
#4 posted 01-24-2015 04:16 AM
I have the same problem with the Dewalt 733, I learned to just cut my pieces longer and cut the snipe off. (shrugs shoulders)
-- Making progress
18351 posts in 1884 days
#5 posted 01-24-2015 04:31 AM
Lifting up on the piece as it goes in has not helped me. I Push down on the piece as it goes in until the wood begins to come out the other side and is therefore under both feeders. On the other end lifting up can indeed help. Perhaps you are not lifting up enough. I have my out feed support on my 733 set so that it goes up just a bit from the bed. Lifting up as it exits pushes on the outfield side roller and therefore forces the wood down against the bed. My 733 has cutter head lock but I don’t use it often, except maybe on the last pass. Basically I just plan to cut the snipe off.
View pintodeluxe's profile
pintodeluxe
5706 posts in 2841 days
#6 posted 01-24-2015 04:31 AM
Raise the outer edges of your infeed and outfeed tables by 1/8”. That should eliminate snipe with most boards. For longer stock, try to lift upward slightly as the piece exits the planer.
View Jim Finn's profile
Jim Finn
2658 posts in 2950 days
#7 posted 01-24-2015 03:09 PM
I had that same planer and lifting the board on each end cured the snipe so I then adjusted the in-feed and out feed tables to do the lifting for me. I had to do the same with my DeWalt planer. Maybe you are not lifting enough.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View davidls's profile
davidls
15 posts in 1569 days
#8 posted 01-25-2015 12:05 AM
I have the DeWalt dw735 and it snipes the ends like all the other planers. If the board is narrow enough make your final pass on the jointer. If it’s too wide then I just make a few passes with a hand plane. This also has the advantage of removing the scallops from the surface.
texretvet
#9 posted 01-25-2015 05:30 AM
I might try raising the infeed and outfeed tables a bit as many of you have suggested.
I will have to take it out and cut it. I put a solid piece of melamine in place of the metal bed and it extends about 12” out the front and 18” out the rear.
