TOOL ANGLES
« back to Coffee Lounge forum
Forum topic by RICH GRABLE posted 04-06-2009 02:47 AM 738 views 0 times favorited 2 replies Add to Favorites Watch
View RICH GRABLE's profile
RICH GRABLE
35 posts in 3376 days
04-06-2009 02:47 AM
HI GUYS, I am wondering what angles I should use when grinding my turning tools. I think I need 3 different angles.
#1 Parting tool
#2 Shews
#3 Gouges
Hope someone out there can help. THANKS
-- RICH GRABLE
2 replies so far
View lew's profile
lew
11895 posts in 3628 days
#1 posted 04-06-2009 03:18 AM
Someone told me to just duplicate the angle that was already ground on the tool.
A book I have gives the following:
Roughing Gouge and Spindle Gouge- 30 degrees
Skew Chisel- 15 to 20 degrees toe to heel.
Parting Tool- 50 degrees (25 degree each side of the point)
View jeffthewoodwacker's profile
jeffthewoodwacker
603 posts in 3677 days
#2 posted 04-06-2009 04:20 AM
I never put my parting tool on the grinder – I use a diamond stone to sharpen it. Your other turning tools can either be ground to the angle that is already on the tool or customized to what works for you. I recommend you either make a jig that will duplicate the angle you like, or purchase a custom made jig like the wolverine. With the jig you should always get the same angle. Go to www.woodturner.org and find a turning club in your area. Most clubs have folks that will help you get started on the correct way to sharpen your tool. Woodcraft and other woodworking businesses offer sharpening classes that are affordable.
-- Those that say it can't be done should not interrupt those who are doing it.
