Painting mdf
Forum topic by txn posted 01-23-2015 09:20 PM 1359 views 0 times favorited 16 replies Add to Favorites Watch
View txn's profile
txn
139 posts in 1422 days
01-23-2015 09:20 PM
What tips or tricks do yall have for painting mdf edges. Every time I’ve tried it soaks up most of the paint is there a primer or something I could apply first before final paint?
16 replies so far
View Tennessee's profile
Tennessee
2860 posts in 2477 days
#1 posted 01-23-2015 09:28 PM
Years ago, when I worked with plywood a lot, I used to say, “No matter what you do, its plywood!” This kind of also applies to MDF.
You are working with ground and chipped wood, pressed together with a bonder. Hard to hide. My first inclination would be to fill it with wood putty to make it smooth, and then sand it and paint the result. I don’t have much more since it is MDF, which is a lower bastard child of plywood. Good luck!
View dhazelton's profile
dhazelton
2753 posts in 2259 days
#2 posted 01-23-2015 09:32 PM
Prime, sand, paint, sand, more paint. Or edge it with poplar or something.
4945 posts in 2456 days
#3 posted 01-23-2015 09:32 PM
If you put something on it first to seal it, and then smooth that out you’ll have better results. That “something else” can be any of a long list…I’ve used glue size (just diluted wood glue, about 4parts water, part glue) and like it, but you could use spackling compound, drywall mud, or possibly just a thick primer.
View MrUnix's profile
MrUnix
6578 posts in 2161 days
#4 posted 01-23-2015 09:42 PM
Just apply more coats.. it will eventually seal up and stop soaking paint. You could also prime first, but it will soak it up just the same.
View firefighterontheside's profile (online now)
17929 posts in 1819 days
#5 posted 01-23-2015 10:05 PM
The glue water mix works. I’ve also just painted thickly for one coat, sanded and recoated with good results.
View CudaDude's profile
CudaDude
179 posts in 2271 days
#6 posted 01-23-2015 10:06 PM
I’ve used automotive filler primer in a rattle can with excellent results. Have to put some work into it though
http://forums.shoryuken.com/discussion/67501/how-to-paint-mdf-to-a-mirror-finish-worklog
-- Gary
View Earlextech's profile
Earlextech
1160 posts in 2653 days
#7 posted 01-23-2015 10:16 PM
+1 with Fred Hargis – I’ve tried everything, but glue size seems to be easiest and quickest. 50/50 wood glue and water. Also works on any routed parts of MDF.
View pjones46's profile
pjones46
1001 posts in 2605 days
#8 posted 01-24-2015 04:01 AM
+1 with Fred Hargis and Sam Hamory
-- Respectfully, Paul
#9 posted 01-24-2015 04:04 AM
I’m making raised panels with MDF tomorrow. I will have to tell my customer who Is doing the painting about this.
View redSLED's profile
redSLED
790 posts in 1855 days
#10 posted 01-25-2015 11:16 PM
Pad on 1 light coat of water-based poly and brush over once – usually dries in 30 min – then fast block-scuff sand with scrap 180/220 sandpaper. Then 2nd coat of same – let dry for 60 min – then final fast scuff sand with scrap 220 – then done! Edge is sealed. I prefer this to using paint primer for the end result. And yes, I know poly costs more than primer. Therefore use up your leftover/dirty/old poly first for this.
View OldRocker's profile
OldRocker
46 posts in 1435 days
#11 posted 01-26-2015 12:51 AM
Dry wall compound works.
-- ....And on the seventh day the Lord created the Les Paul...and it was good.
#12 posted 01-26-2015 12:57 AM
Made MDF raised panels yesterday for a customer. They turned out great, but I’m glad I’m not the one painting it. I’ll pass on these ideas though.
View AlaskaGuy's profile
AlaskaGuy
4041 posts in 2272 days
#13 posted 01-26-2015 08:33 AM
http://www.finewoodworking.com/how-to/article/tips-for-painting-mdf.aspx
Haven’t done it but I’d think the glue diluted with water could swell the fibers.
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1189 days
#14 posted 01-26-2015 10:45 AM
For the edge I would run my finger down it with some Water Putty sand then again
-- If you don't Play, you can't win
AlaskaGuy
#15 posted 01-26-2015 11:26 AM
- Garbanzolasvegas
Have fun sanding that stuff when it dries.
