shipping container workshop in Seattle, Wa
Forum topic by BRICKELCREEK posted 01-22-2015 09:00 PM 6050 views 1 time favorited 8 replies Add to Favorites Watch
View BRICKELCREEK's profile
BRICKELCREEK
11 posts in 1505 days
01-22-2015 09:00 PM
Topic tags/keywords: shipping container shipping container shop woodshop
I recently built a woodshop out of two 20’shipping containers. I know this is an idea that more than a few folks have had so I’d be happy to answer any questions about the process. You can check out how it went together at my blog.
http://www.brickelcreekwoodwork.com/blog/2015/1/15/building-a-woodshop-out-of-shipping-containers
-- BRICKELCREEK, Seattle WA, http://www.brickelcreekwoodwork.com
8 replies so far
View RadioActiveRich's profile
RadioActiveRich
68 posts in 1421 days
#1 posted 01-22-2015 09:03 PM
This is awesome. I’ll definitely check out the blog.
My main question is with regard to sound. I am worried that if I build my second shop like this I’ll go deaf with the noise bouncing off of every surface. Are you going to address that in your construction or should I just get a second layer of hearing protection?
Thanks for the post btw. ;)
BRICKELCREEK
#2 posted 01-22-2015 09:10 PM
Surprisingly its no louder than a normal space. I was worried about it too and considered mounting acoustic tiles to the ceiling, but after I filled up the shop with tools, supplies, cabinets and stock there was enough material to absorb the sound. I was also worried about the sound outside of the containers giving my neighbors a headache, especially when running the planer. Again I was pleased to find that it was no more noisy than a garage or backyard shed. I always where hearing protection too:)
View crank49's profile
crank49
4029 posts in 2875 days
#3 posted 01-22-2015 11:24 PM
Just have to deal with a slightly less than 8 ft ceiling though, don’t you.
BRICKELCREEK
#4 posted 01-23-2015 12:34 AM
Just have to deal with a slightly less than 8 ft ceiling though, don t you.
- crank49
Your right, the finish height is about 1/2” shy of 8ft because of the osb floor.
View redSLED's profile
redSLED
790 posts in 1797 days
#5 posted 01-23-2015 12:39 AM
Loving it. Nicely done.
I never would’ve thought you could cut those with a grinder.
Ball park total cost so far without the electrical work – under $4000? And including the concrete pad if you had to build that first? If you don’t mind me asking.
BRICKELCREEK
#6 posted 01-23-2015 12:49 AM
I never would ve thought you could cut those well enough with a grinder.
Ball park total cost so far without the electrical work – under $4000? And including the concrete pad if you had to build that first? If you don t mind me asking.
- redSLED
Your pretty close, the used containers can be purchased here in Seattle for about $1500 a piece. If you had to pour a pad you might be closer to $5000 total. Since the containers only need to be supported on the corners I would probably use concrete piers if I was to move the shop into my backyard.
runswithscissors
2652 posts in 1929 days
#7 posted 01-23-2015 07:08 AM
How did you join the 2 halves to make a waterproof roof joint in the middle? (I know you don’t have to worry about snow load).
RadioActiveRich
#8 posted 01-23-2015 07:21 AM
@BrickelCreek – Nice! I was hoping the shape of the metal would deflect some of the sound. Maybe that is what’s happening. As for neighbors, my second shop will be on 10 acres of land surrounded by … well … nothing. So, I don’t have that worry.
Nicely done and very helpful. Thanks for the post. I’ll be watching the blog too. ;)
