Air Random orbital sander
Forum topic by Craftsman on the lake posted 04-04-2009 06:33 AM 2071 views 0 times favorited 4 replies Add to Favorites Watch
2842 posts in 3671 days
04-04-2009 06:33 AM
Topic tags/keywords: sander random orbital sander pneumatic compressor sand air tools
I’ve only had a stationary belt sander. I usually hand sand and use hand scrapers But sometimes I think I could use a sander. I’ve got lots of air, 60 gal. tank and 5hp compressor. And I like air tools. Does anyone have any experience with a pneumatic random orbital sander? If so, recommend a brand or features? Thanks in advance.
View kiwi1969's profile
kiwi1969
608 posts in 3675 days
#1 posted 04-04-2009 06:44 AM
Only used them in factories with big compressors so can,t comment on if your compressor will handle it, but i sounds like it will. Performance wise they are fantastic and to be honest most of the ones i,ve used were not even brand name tools. On the downside i have to say they are a lot louder than electric and they can vibrate badly and you need a good water trap on your line.
View Chiefk's profile
Chiefk
163 posts in 4004 days
#2 posted 04-04-2009 02:59 PM
Daniel, I have a Dynabrade sander. The sander is very light and does and excellent job. They use alot of air and the compressor ( at least my 60 gal ) will run almost non-stop while you are using the sander. You will also need a water filter on your compressor line. Good luck, pkennedy
-- P Kennedy Crossville, TN
View AceKing's profile
AceKing
2 posts in 2735 days
#3 posted 07-21-2011 06:16 AM
Craftsman:
In addition to the fine brands mentioned above, Ingersoll Rand also makes some excellent industrial grade sanders. As Rick3ddd mentioned above, what you want to keep in mind is the type of finish desired. The 3/16” orbit models are better for rough work while the 3/32” orbit models are better for swirl free finishing. 5” and 6” pads are the norm when dealing with Random Orbital Sanders (ROS) Here are examples of each:
3/16 Orbit Model
3/32 Orbit Model
The tools mentioned above are American made. If you are interested in something a little more general purpose the IR4151 is also a decent import choice.
Hope this helps.
Aceking- San Diego, CA
-- Not here for a long time, just a good time!
View ,'s profile
2387 posts in 3780 days
#4 posted 07-21-2011 07:42 AM
HP ratings are often decieving, you will want to look at the stated cfm output of your air compressor to ensure it would run a sander which is an air hog.
