Black Locust
Forum topic by VADesigner posted 01-22-2015 07:08 PM 1045 views 0 times favorited 5 replies Add to Favorites Watch
View VADesigner's profile
VADesigner
2 posts in 3173 days
01-22-2015 07:08 PM
Topic tags/keywords: lumber black locust virginia west virginia
I’m looking for a supplier of Black Locust in the Shenandoah Valley of Virginia. Am willing to travel over the mountain or down the river to WV as well.
Anyhow, if there are any growers out there reading this, I thought I’d share this older article. There’s a market to be had in Black Locust: http://dirt.asla.org/2011/11/10/why-use-ipe-when-you-can-have-black-locust/
“Currently, there are 5 million acres of Black Locust under cultivation worldwide, but “virtually zero in the U.S.” Korea has 1.2 million acres, China has another 1 million, while Hungary has 270,000 acres. “This is something that has the potential to be an economic engine in many parts of this country.”
Start planting now!
5 replies so far
View Jeff Heath's profile
Jeff Heath
67 posts in 3150 days
#1 posted 01-22-2015 08:54 PM
You need to find your local sawyers. If you check on the forestryforum.com website, or with woodmizer, you can be put in touch with a local sawyer who cuts locust.
I own a woodmizer mill, and spend a lot of time on the forestry forum. There are several threads running right now about locust.
-- Jeff Heath
runswithscissors
2804 posts in 2105 days
#2 posted 01-23-2015 07:15 AM
It’s an interesting wood. The legend is that you can plant it in the ground for fenceposts, then after 50 years yank out the posts and turn them end for end for another 50 years.
It steam (or heat) bends quite well, and is occasionally used for bent frames in boats.
Around here (Pac NW) I think most of it is wild, but I know of no stands of it. Specimen trees in yards, too.
View wbrisett's profile
wbrisett
203 posts in 2429 days
#3 posted 01-23-2015 08:34 AM
I looked at planting a tree or two of this, but was warned by local arborist that it is considered invasive. Thus the reason I suspect you don’t see much of it here. Apparently the root system will get into everything.
http://www.wildflower.org/expert/show.php?id=9041
View lndfilwiz's profile
lndfilwiz
106 posts in 1681 days
#4 posted 01-23-2015 03:53 PM
Invasive, yes! There is hundreds of acres of black locust in WNY! They have massive root systems and will take over any open field that has good drainage. They are fast growing. I have harvested (500) 8’ posts off 2 acres and 5 years later harvested 1000. To uses for posts they have to be well seasoned. Otherwise they will begin to grow if placed in soil while they are still green!
-- Smile, it makes people wander what you are up to.
View Steve Peterson's profile
Steve Peterson
387 posts in 3163 days
#5 posted 01-23-2015 05:22 PM
I had two honey locust trees grafted onto black locust rootstock that were purchased at a nursery. The yard had lots of black locust suckers. I left a few of them to grow because I liked the shade. They were about 20’ tall and 5” in diameter within about 5 years.
The yard was continuously sending up black locust suckers. It was getting harder and harder to control the suckers. I would say that they are quite invasive.
-- Steve
