Foredom Grinder-Carver Stand
Forum topic by Kelly posted 01-22-2015 07:06 PM 802 views 0 times favorited 0 replies Add to Favorites Watch
View Kelly's profile
Kelly
2104 posts in 3120 days
01-22-2015 07:06 PM
Topic tags/keywords: rotary tool flex shaft foredom fordom dremel carver grinder carve grind
Just thought I’d post this to remind folks there are nice options for rotary shaft tools using re-purposed items.
I picked this IV stand up at a garage sale for under ten bucks. A quick search on line shows you can pick them up everywhere for sixty bucks. If you need one on the cheap, you might inquire at the local clinics and hospitals.
The stand is easily adjustable to any height you need. It is reasonably stable when being moved and very stable in use.
This would work fine for Dremel type flex shafts too.
0 replies so far
