mini shelves for pegboard
Forum topic by cdstudioNH posted 01-22-2015 05:46 PM 863 views 0 times favorited 6 replies Add to Favorites Watch
View cdstudioNH's profile
cdstudioNH
27 posts in 1304 days
01-22-2015 05:46 PM
Topic tags/keywords: shelves small pegboard organization
Hi there!
I have the need for about a dozen mini shelves that I want to make and somehow attach to pegboard.
Any suggestions?
View MrUnix's profile
MrUnix
6773 posts in 2228 days
#1 posted 01-22-2015 05:50 PM
(there are solid metal ones available as well)
cdstudioNH
#2 posted 01-22-2015 05:59 PM
Thanks! No, I have lots of those. I should have given dimensions:
I would like about a dozen mini shelves, approx. 5” x 8”, so 5” deep and 8” wide
I think those are about 10-12” and protrude too much for what I need.
They will hold no more than 1.5 lbs
MrUnix
#3 posted 01-22-2015 06:04 PM
They come in all different sizes.. but here is another solution that just uses the hooks connected to the back of, in this case, a 1×4 board:
https://www.youtube.com/watch?v=Yn8ikVWSY_w
Or here is another idea:
https://www.youtube.com/watch?x-yt-cl=84359240&v=tLsYzNU5Q28&x-yt-ts=1421782837
I’ve also used the regular pegboard hangers (vary in length from about an inch on out to about 12”) and just placed a piece of wood on top. Lots of options, all pretty simple. If you can’t find a stock length, it’s not too hard to cut them to the length you need. You can also secure the board to whatever you use as a support with a couple of clips to keep it from moving once installed.
View ClayandNancy's profile
ClayandNancy
519 posts in 3044 days
#4 posted 01-22-2015 06:18 PM
I have made shelves and small drawer units and have used an el screw in to the edge of a 1/4. Same in theory as what MrUnix shared in the video only screwed in to the wood rather than just slipped over. Then just tip your shelf up and slide the hooks into the holes in the pegboard and bingo.
cdstudioNH
#5 posted 01-22-2015 06:46 PM
Nice!! Both the videos are great! And I LOVE the idea of el screws.. brilliant!! I’ll post pics of what I do this weekend.
~ Cynthia
View MinnesotaMarty's profile
MinnesotaMarty
126 posts in 1247 days
#6 posted 01-31-2015 03:52 AM
Brad in Fl.
thanks for the videos. Laney does a great job explaining things, you can’t miss watching his stuff.
Marty
-- I can see the cheese heads from here and it is great.
