| Forum topic by diver | posted 239 days ago | 237 views | 0 times favorited | 8 replies | ![]() |
239 days ago |
Topic tags/keywords: question rustic Thanks, all, for your ‘welcome to LJ’ notes. I’m a beginning woodworker and am looking forward to seeing your projects and learning as much as I can from your experience. I have a question to start out with: I’m building a rustic-style rocking chair for my sister’s 50th birthday, out of large yew sticks. For the ‘rocker’ pieces I though of using maple or oak lumber cut to the appropriate arc, and attached to the yew chairframe with tenons. Anything special I should know about those rocker pieces? the way the grain goes? A different material than maple or oak? Any other words of advice on such a project? —mb -- mb |
238 days ago |
The grain definitely need to run length wise. -- Debt is nothing more than the 21st Century's form of slavery. |
238 days ago |
I would think that you’d want to get long tight grained runners. -- Gary, South Central Wisconsin. So much to learn, so little time! |
237 days ago |
Yew? Hey send me some too! That stuff is awesome! ypu might want to consider using Maple because of simple design reasons, maple would look best with yew. Oak, probably not, the woods (yew and oak), in my opinion do not go together. as the others said, use straight grain. And grain that runs length wise. might consider doing a form glue up for the runners, so make a form and counter form and stack and glue up a number of 5mm or 1/4 inch or so strips into a curved form… usenormal white glue and works great and is very stabil. -- Nicholas, Journeyman Cabinetmaker, Partenkirchen, Germany |
236 days ago |
Hi All, Always, in every piece, for every item you layout on wood, the long straw-like grain micro-structure should run along in the same direction as that particular parts’ longest dimension for strength, structural integrity, load-bearing, and durability. Never run the grain in the direction of your shorter dimensions as it is not favoring it’s optimal strength of the natural grain patterns. There are some exceptions, like if making a carving of a monk with outstretched praying hands, when running the grain along the monks body and torso the hands situated 90 degrees to the body might break off unless made of separate stock also with the grain running to favor and strengthen the monks’ outstretched hands. Then both body and hands will be at their optimal strength configurations when then glued together for superior durability and lasting integrity (as long as you use a good glue or epoxy!). Carl |
236 days ago |
To all who responded: thanks! And especially Nicholas—what a great idea to laminate maple strips. That’ll be much stronger than a single piece of lumber. I never would have thought of it on my own. For a large-ish chair, the runners should be about 4 feet in length, don’t you think? The yew is very interesting: the sapwood isn’t much to look at, but the heartwood is gorgeous. And the bark is beautiful too. I limbed-up some really old yew shrubs at a friend’s house and harvested some branches about 2.5-3” caliper. It’s a real challenge to use since it’s very twisted and curvy and rather brittle. I’m bracing and cross-bracing like crazy since I don’t want anyone who sits in the chair to end up in a heap of sticks on the floor! -- mb |
236 days ago |
You are certanly welcome! I like to help where I can! Yeah, I think 4 foot sounds good, should work, I must admitt though I am no expert in making rocking chair runners and but have more expierence in runners for sleds! (sleds have to hold up to some punishment too!) Sounds like a neat project, you should post it when its done. Perhaps make pics and a blog on it while its being built. -- Nicholas, Journeyman Cabinetmaker, Partenkirchen, Germany |
236 days ago |
I have a large piece of cherry in storage from which I intend to cut rocker pieces. It has tight, sweeping curves in it due to unusual growing conditions. The rockers will have long grain following the curves all the way. d -- If a man says something in the forest and there's no woman to hear it, is he still wrong? |
232 days ago |
When I make my rockers..I cut and glue up 7 strips 1/2” wide by 1/8th in thickness to allow for easier bending. I have a form that I made that’s about 4”thick curved the shape I want the rockers to take plus a little more to allow for springback the form has 2” cross slats attached to the bottom to keep the rocker slats from slipping off the form itself..springback is not alot..but it does do it..I glue up using tightbond 2 yellow glue and use about 12 clamps. I apply the glue liberally to both sides of the slats with the exception of the top and bottom slat for obvious reasons.. and I let it sit, clamped in the form for about 2 or 3 days. the form also has plastic laminate on it because the glue will not stick to it and allows the glued up rocker to be removed from the form. you can use tape if you don’t have any laminate to line the form with -- Randall Child |
| Forum | Topics |
Woodworking Skill Share
2925 |
3956 |
257 |
954 |
225 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
