Sketchup stretch ruby script
Forum topic by spaids posted 238 days ago 982 views 0 times favorited 16 replies Add to Favorites Watch
View spaids's profile
spaids
460 posts in 590 days
238 days ago
I saw a video tutorial on line showing a ruby plug in that can stretch a piece with tenons and not screw up the tenon dimensions. It would change the group highlight box to green when you were using it. I thought hey that cool I’ll have to revisit this later and get this plug in. Now I can not for the life of me find this thing. BAH Anybody seen this?
Spaids
-- Wipe the blood stains from your blade before coming in.
View Robert Palmeter's profile
Robert Palmeter
15 posts in 277 days
238 days ago
That is Free Scale 2.0b beta.You will have to register to download and there is a second download to make Free Scale work. This is a great plug in.
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a
There is a link on FWW Design click Build blog
http://finewoodworking.taunton.com/item/11367/freescale-20a-beta
Robert
-- I don't understand everything I know about this.
spaids
238 days ago
YES! Gees I can’t believe I couldn’t remember where I saw that. I even have a short cut for the FWW RSS feed on my browser! DUH! Good thing I sharp chisels because I am obviously not very sharp.
Thanks
View DaveR's profile
DaveR
1527 posts in 617 days
238 days ago
I was going to post a link to my blog post on the plugin but I didn’t want it to be seen as blowing my own horn.
-- Until you spread your wings, you'll have no idea how far you can walk.
View turkva's profile
turkva
24 posts in 843 days
237 days ago
Freescale is an awesome plugin, it does a whole lot more than just lengthen rails with tenons. You can warp, twist, taper and a lot more.
-- Accept Nothing, Challenge Everything
DaveR
237 days ago
Yes, I know that. As I indicated in my blog I was only showing a little of what it does.
spaids
237 days ago
what are the units when you stretch a board
It would be nice to do the start and type thing.
DaveR
237 days ago
I use inches. It depends upon how you’ve set up Sketchup.
The cool thing for stretching a rail is that if you hit Ctrl, it’ll stretch in both directions from the center. You could place a copy of a rail component midway between the legs or stiles and stretch it to fit the space. Or, of course you can stretch only on one end but where’s the excitement in that? :)
spaids
237 days ago
I use my setup in inches but when I try to stretch with this tool it doesn’t display in inches in the text box and if I type something small like 2 it stretches much more than 2 inches.
So
I select a board, click the stretch tool, grab the green box, move in the direction I want, type a number and hit enter. Thats what I’m doing but its not going by inches. Its like its some kind of absolute number or something. It always starts at 1. Like its giving some kind of size ratio instead of change in inches.
Thanks for the help
DaveR
237 days ago
I’m off to a meeting but when I get home, i’ll try to help. check for a PM from me.
Robert Palmeter
237 days ago
I am having the same problem at times. Works fine one time but not the next. I cannot figure what I’m doing differently in these instances.
Robert
DaveR
237 days ago
After activating the tool, hover over the handle on the end where you want the stretch to occur, hit Tab and type in the new desired dimension. Hit OK.
Robert Palmeter
236 days ago
Thanks Dave. Until I found your blogs SU was totally frustrating. Now I don’t start a project without SU being the first step after the honey-do order.
Robert
View depictureboy's profile
depictureboy
309 posts in 540 days
194 days ago
I cant get it not to deform my object. Think you can take a look dave?
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
DaveR
194 days ago
Yep. Send me the file. Do you need my e-mail address?
depictureboy
194 days ago
never mind, I figured out my error…I was using scale instead of stretch…thanks anyway :)
DaveR
194 days ago
Glad I could help. :-D
