Stationary Sander
Forum topic by Bugnurd posted 01-22-2015 01:53 PM 858 views 0 times favorited 8 replies Add to Favorites Watch
View Bugnurd's profile
Bugnurd
105 posts in 1613 days
01-22-2015 01:53 PM
Hey all,
If you had the choice between a disc/belt combo machine with a 9” disc verses a standalone disc sander with a 12” disc, which would you go for, assuming all else is equal (price, quality, power, condition, etc.) You can’t get both, even though that would be the “correct” answer. I’d like to hear your thoughts on sanders…
Go.
-- Marc -- Worcester, MA
8 replies so far
View Gene Howe's profile
Gene Howe
10521 posts in 3450 days
#1 posted 01-22-2015 02:12 PM
It really depends on your methods of work.
Which one would get the most use in your shop?
My belt sanders get far more use than my disk sanders. But, when I need to use the disk sander, nothing else will do….handily.
View JoeinGa's profile (online now)
JoeinGa
7736 posts in 2029 days
#2 posted 01-22-2015 02:16 PM
If you have a motor, you can build your own 12” disc sander. Here’s mine…
http://lumberjocks.com/JoeinGa/blog/34349
View ChefHDAN's profile
ChefHDAN
1067 posts in 2871 days
#3 posted 01-22-2015 02:34 PM
+1 to Gene, I’ve got a ryobi belt and disc combo, (was a great deal for $50) and a Clayton oscillating spindle, most every piece no mater the level seems to have me use the belt sander, & when I switch it to the horizontal position it can sharpen a blade lickety split!
View gfadvm's profile
gfadvm
14940 posts in 2712 days
#4 posted 01-22-2015 02:36 PM
The belt side of my combo gets a lot more use so I’d vote for the combo (the bigger, the better).
View DIYaholic's profile
DIYaholic
19623 posts in 2697 days
#5 posted 01-22-2015 03:17 PM
Since getting my Ridgid OSS/belt sander….
My Ryobi combo disk/belt sander sees little use.
However, it really depends upon YOUR needs!!!
Were I to start all over….
I’d get the Ridgid OSS/belt sander first, then build or buy a 12” disk sander.
View Ripthorn's profile
Ripthorn
1458 posts in 3007 days
#6 posted 01-22-2015 03:28 PM
I have the ROSS but still want a nice, beefy belt/disc combo. Then again, I do some metal working like making occasional infill planes and the ROSS, while great for certain things, is not a robust machine as far as sanding metal is concerned (not what it’s built for). So the correct answer depends on “what are you doing with it”, as a regular disc sander would see a lot of use in some shops and not much in others.
View helluvawreck's profile
helluvawreck
31348 posts in 2889 days
#7 posted 01-22-2015 04:18 PM
I have a PM belt disc sander and I use both the disc and sander quite frequently. I also have a spindle sander and use it as well. I would not like to be without any of these three. I hope to be able to get a drum sander on down the road.
helluvawreck aka Charles
16275 posts in 4240 days
#8 posted 01-22-2015 04:28 PM
If I understand the question correctly, you are really asking if it is worth giving up three inches of diameter in the disc sander to gain the addition of a belt sander. I would say “absolutely”. I have a belt/disc combo, and I use the belt a lot more often than the disc. Your mileage may vary, of course, but I think you will find both belt and disc very useful.
