Looking for a temporary spray adhesive
Forum topic by Billyboy posted 04-03-2009 06:13 AM 16694 views 3 times favorited 11 replies Add to Favorites Watch
View Billyboy's profile
Billyboy
9 posts in 3649 days
04-03-2009 06:13 AM
Topic tags/keywords: question tip
I’ve been making wooden toys and part of the process is adhering paper templates to the raw wood pieces before I cut them out on the band saw or other tool. I’ve been using two-sided carpet tape to stick the paper to the wood but have been unhappy with the results – the paper adheres too well.
I’ve noticed that folks talk about using a spray adhesive instead of carpet tape but I don’t know which type and/or brand to buy. Obviously, I don’t want something that makes a permanent seal, I just want the paper to stick to the wood until I can cut it out.
Any suggestions?
11 replies so far
View interpim's profile
interpim
1170 posts in 3699 days
#1 posted 04-03-2009 06:27 AM
I’ve used the 3M spray adhesive… it stays tacky forever it seems. It will hold paper tight, but the residue can be a pain to remove, but that goes for most spray adhesives.
-- San Diego, CA
View MrWoody's profile
MrWoody
328 posts in 4015 days
#2 posted 04-03-2009 12:46 PM
I found that spray adhesive was too messy for this application. I use Elmer’s Rubber Paper cement. I got mine at an office supply store, I’m it’s available elswhere.
-- If we learn from our mistakes, I'm getting a fantastic education.
View BigFoot Products Canada's profile
711 posts in 3634 days
#3 posted 04-03-2009 02:13 PM
KRYLON Easy Tack.. It’s the best.
View spaids's profile
spaids
699 posts in 3934 days
#4 posted 04-03-2009 02:25 PM
I’ve got some 3M that I use to stick the pattern for making those little 2×4 reindeer. Its just the can that was on the shelf at Walmart. I think it says on the can to spray on one surface for a temporary stick and spray on both surfaces for a more “permanent” adhesion. I don’t know how permanent it could actually hold but it works great for sticking on a pattern to get band sawed. I spray the back of the paper and stick it so there isn’t a tacky surface on the parts of the wood that don’t need it. It’s a piece of cake Billy you’ll have no trouble.
-- Wipe the blood stains from your blade before coming in.--
View rickf16's profile
rickf16
392 posts in 3822 days
#5 posted 04-03-2009 02:38 PM
Here is a different take on adhering patterns to wood. My wife is a scrapper,(scrap booking, not a fighter). I needed to attach small patterns to band saw and did not have any spray adhesive. What’s woodworker to do! I asked my wife if she anything and she suggested I try this :Herma Dotto Dots Dispenser – Temporary. Take a look at the link. I have used this quite bit and I think it works great. No messy spray to deal with and the patterns come off with very little residue. Any left over adhesive just rubs off with your finger. Works great for small patterns. Should be able to find them at any scrapbooking store. My wife had two, not any more! adhesive dispenser
-- Rick
View Frankie Talarico Jr.'s profile
353 posts in 3597 days
#6 posted 04-03-2009 02:43 PM
sta-put is a aerosal can comes in red and clear, This is a pretty tough contact adhesive. It’s used to attach veneers and such. With a pretty permanent hold, Unless you have laquer thinner. It cleans off pretty quickly and takes 10 seconds to dry.
You can buy these at cabinet hardware supply shops
seems like Herma Dotto Dots Dispenser might be your best bet
-- Live by what you believe, not what they want you to believe.
View bayspt's profile
bayspt
292 posts in 3945 days
#7 posted 04-03-2009 03:37 PM
I vote for the supper 77 as well.
-- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!"
View Greg's profile
Greg
221 posts in 3699 days
#8 posted 04-03-2009 04:38 PM
I do a lot of scrollsaw work and use either Elmer’s or Duro spray adhesive to glue up patterns, both should be available at wally world or HD or Lowe’s. Also I put blue painters tape on the wood first then glue the pattern to the tape, makes for real easy removal, some people will use clear packing tape instead of the blue tape, but I found that the blue tape leaves no residue.
-- Greg S.E. Ga. www.thesawdustfactory.net
View Matt's profile
Matt
181 posts in 3613 days
#9 posted 04-03-2009 05:18 PM
I agree with the 3M Super 77 stuff. I usually spray only 1 side then I let it sit for a few minutes. This lets it set up some so it’s only ‘tacky’. I don’t go crazy when I put it on the wood and rub it down very tightly. Just enough to make it all stick close to the surface. When I’m done, it usually peels off with very little residue left over. I used to use it on RC airplane parts. I used thin paper so if any of it did stick it would sand off easily.
Hope that helps.
-- Matt - My Websites - http://www.bestinwood.com - Hand Tools :: http://www.workshopgarage.com - Small Shops
View MrsN's profile
MrsN
987 posts in 3767 days
#10 posted 04-03-2009 07:41 PM
I agree with Greg. I also do some scrollsaw work and have found that the combination of tape and spray glue works really well. I use clear packing tape (i think i currently have duct brand, but i am not in my shop to check) and duro spray adhesive. If the packing tape sticks to well, I use an old hair dryer to warm it up a little and it comes off clean.
Billyboy
#11 posted 04-03-2009 11:46 PM
Thanks to all of you for your great advice. I particularly like Greg’s idea to use blue painters tape first, thus eliminating the adhesive residue on the object. I think I’ll try a couple of the recommended adhesive sprays too.
