Motor for bandsaw?
Forum topic by azlogger posted 01-22-2015 05:50 AM 3048 views 0 times favorited 23 replies Add to Favorites Watch
View azlogger's profile
azlogger
37 posts in 1767 days
01-22-2015 05:50 AM
Topic tags/keywords: homemade bandsaw motor
I recently finished building Matthias Wandel’s 16” bandsaw. I’ve been using it some with an underpowered washing machine motor, and I’m ready to put a better motor on. But I don’t want to spend $150+ on a motor. Can anyone point me to a motor for less money? Needs to be AT LEAST 1/2 hp…more if possible. 115V, single phase… 1725 rpm preferred. I’ve been watching Craigslist for some power tool with a motor, but nothing has come up for less than I can can buy a new motor for. Also, is there a reason NOT to use a swamp cooler motor? They are cheap but I don’t often see diy toolmakers using them. Thanks! —Jer
-- Who needs PLANS??!! Be original!!
23 replies so far
runswithscissors
2846 posts in 2174 days
#1 posted 01-22-2015 08:09 AM
You can use a 3450 rpm motor on it simply by putting a larger pulley on the driven wheel, and a small one on the motor. And doing so has the advantage of increasing your available power.
View Minorhero's profile
Minorhero
373 posts in 2754 days
#2 posted 01-22-2015 09:04 AM
EBay is a good source for old motors. You may need to replace bearings, but other than that not a lot to go wrong on a motor. Shipping usually costs 40 to 60 dollars for a motor. So finding one you can do a local pickup on will be important. No idea what a swamp cooler motor is.
View jackhmrz's profile
jackhmrz
9 posts in 1369 days
#3 posted 01-22-2015 07:36 PM
You can sometimes find cheap motors on craigslist also.
I wonder how well a variable speed treadmill motor would work?
For mine I got a cheap 3 phase motor from CL and a new 115V input VFD
That is >$150 but gives variable speed.
View jakep_82's profile
jakep_82
105 posts in 2455 days
#4 posted 01-22-2015 08:10 PM
I would consider finding an old treadmill. They pop up on CList in my area all the time for $20-$50, and most have 2+ HP motors.
azlogger
#5 posted 01-22-2015 08:11 PM
Funny you mention that…I happen to have a three phase motor just laying around, and I was thinking of doing that! But it’s a 440v…and I haven’t found a VFD that goes 110-440.
View mpounders's profile
mpounders
890 posts in 3044 days
#6 posted 01-22-2015 08:18 PM
Harbor Freight has a 1/2hp 1800 rpm motor for around $100. You can easily find 20% discount coupons and get it for less.
-- Mike P., Arkansas, http://mikepounders.weebly.com
jackhmrz
#7 posted 01-22-2015 08:39 PM
Funny you mention that…I happen to have a three phase motor just laying around, and I was thinking of doing that! But it s a 440v…and I haven t found a VFD that goes 110-440.
- azlogger
Not sure but I think some/all motors can be rewired 440 to 220.
You might check for a schematic inside the connection box.
View oltexasboy1's profile
oltexasboy1
250 posts in 1853 days
#8 posted 01-22-2015 08:43 PM
I have a 3/4 HP ,1825 RPM, motor you can have if you live close enough to Houston to pick it up. The shipping would be more than a new motor. It is American made BTW
-- "The pursuit of perfection often yields excellence"
azlogger
#9 posted 01-22-2015 09:06 PM
- oltexasboy1
I’m in AZ…so probably won’t be picking it up. Thanks anyway!
azlogger
#10 posted 01-23-2015 01:24 AM
Well, I just left Harbor Freight with a motor… Thank you all for the advice!
jackhmrz
#11 posted 02-08-2015 02:48 AM
How did it work out?
View Dan658's profile
Dan658
93 posts in 1419 days
#12 posted 02-08-2015 03:00 AM
Have you checked the classified ads for old table saws? More often than not in my area, I see old beat up table saws with +/-1hp motors. Then you just do what runswithscissors said. I got a 1-3/4hp Walker-Turner for free with an old jointer because the guy was moving and didn’t want to take it. Keep your eyes out. EDIT I clearly missed the part where you said you purchased one. New works too!
I’ve been thinking about making a Wandelsaw for a little while and I don’t know if I want to make his 14” with increased cut capacity or the 16”. What made you go with the 16”?
azlogger
#13 posted 02-08-2015 03:16 AM
The HF motor has worked out well. It has a very fast start, and it normally slips the belt just a tiny bit on startup. Other than that it is great.
As for what made me choose the 16”... Really nothing but the extra 2”. I had no intention of using it as a sawmill, so I didn’t see any real advantage to the 14”. The 14” may be slightly easier to build, but I thought I could handle it and I was rewarded by a slightly larger machine…
azlogger
#14 posted 02-08-2015 03:32 AM
Here’s the finished bandsaw.
I made a video of making the trunnions using my CNC Machine: CNC Cut Trunions
Dan658
#15 posted 02-08-2015 03:35 AM
Here s the finished bandsaw.
- azlogger
Very cool. What was the material cost, if you don’t mind me asking?
