| Forum topic by BlankMan | posted 238 days ago | 891 views | 0 times favorited | 23 replies | ![]() |
238 days ago |
I’ve been wondering about this for a while and been thinking about asking it here so here it is. I’d like to hear what people think about them. I personally am not sold on the concept although I know the merits of granite and purchased a Toolroom Grade Granite Surface Plate for a flat surface for honing and such a long time ago. I personally would not buy a machine with a granite top, I’d stick to cast iron even if there is more maintenance required. I have to think the only reason manufacturers have gone to granite is to reduce their costs and I highly doubt they are passing that savings on in its entirety to the customer. I’m still on the fence whether this qualifies as just another gimmick. One drawback I see to granite is, you drop something heavy on it, like a hammer or a Bessey Tradesman Clamp or Pony Pipe Clamp ( I say that because in my case my clamp storage is overhead between the joists in my basement and when grabbing a clamp they have slipped and dropped) and were it to hit the edge of the slab or the mitre slot edge there’s a good chance you will chip it. Another drawback being along the same lines, using a mitre gauge in the slot that has the washer on the end and through some mis-movement when sliding it out you angle it and and chip off part of the top of the T-slot (I think this would be rather easy to do). Granted both of these scenarios may not happen but there is some likelihood that they could happen and boy, I sure would be one PO’d woodworker in that I just damaged my nice granite table top. -- -Curt, Milwaukee, WI |
238 days ago |
I’ve read too much about granite counter tops being full of uranium to want that stuff in my home. I read an article (sorry I can’t locate it) a while ago about a service that would scan your granite tops with a Geiger counter to make sure they were not poisonous. The gist of the article was that they kept having problems with counter top and rock companies not letting them in to scan the merchandise before it was installed in the client’s home. Almost like they knew there was a problem… -- He said wood...http://hickbyassociation.blogspot.com/ |
238 days ago |
If you do chip it though it’s pretty easy to repair with some epoxy… -- I am always doing that which I can not do, in order that I may learn how to do it. - Pablo Picasso |
238 days ago |
I thought long and hard about this when I was looking for a new 3hp cabinet saw. Saw one in person at the Ended up buying the Grizz 1023. No regrets… -- BarryR Virginia |
238 days ago |
For people that live in high humidity area’s the tops are good for not rusting. Other than that I don’t think I would want one. |
238 days ago |
The granite looks nice, but I share your concerns about this. I noticed that Steel City offers a 10 year warranty on their granite tops. This sounds good, but the fact that they need to offer the warranty may indicate that it won’t hold up as well as cast iron. I think only time will tell whether or not this material holds up well in the shop. -- Daniel, Southern Indiana -- "Have nothing in your home that you do not know to be useful or believe to be beautiful." -- http://blackdogwoodshop.etsy.com |
238 days ago |
High humidity areas, where would that be, like Florida? Is that really a problem? Mine are in the basement and during the summer our outdoor humidity can range in the 80’s, 90’s and it’s all of that in my basement. I do run a dehumidifier on a timer for some hours everyday in the summer months (it has an internal humidity level control also), I’ve never had problems with rust forming on anything. Unless I splashed some water on one and didn’t wipe it off. Or, left pressure treated lumber sit on my table saw overnight, that does it in a hurry, unbelievably in a hurry. Does Steel City’s warranty hold if it gets chipped they’ll replace it, or the usual, against manufacturing workmanship and/or defects? Which, if you get a 5 year on cast iron for manufacturing workmanship and/or defects verses 10 years on granite for manufacturing workmanship and/or defects that doesn’t mean much to me, If you get past the 5 years, probably even 2 years, you’re pretty much home free anyway. But, 10 years, if it suddenly developed a crack, that would be a good thing, as long they don’t try to say you caused it, and as long as Steel City’s still around… Anyone remember Star? -- -Curt, Milwaukee, WI |
238 days ago |
Maybe it’s not humidity, I don’t know I live in the dry desert, but there have been topics on this before just search granite tops, a lot of people live in areas where they have to protect there iron surfaces from moisture wherever it’s coming from. |
238 days ago |
Well a little wax, etc to keep them from rusting and make the top nice and slick is not exactly a huge issue. You should really wax the granite too, its porous and wicks up water like the cast iron does. This just poses a different issue. Using Granite is about stability. IE they don’t need to treat the cast iron with destressing heat prior to machining. Just cut a slab, machine it flat and stick it on a saw. This amounts a a HUGE savings in not only labor and energy, but warranty claims. The import cast iron is not exactly great stuff. How many people have you seen complain about warping? Didn’t use to happen when it was made in the US with mehite iron. Started with the Taiwan machines and improper processing. Now with granite they can get around that. They just need to get over the acceptance hump. I’m not going to argue if its good or bad for machine tools. But I can guarantee you that this is what it is about. Reduced labor, energy cost, and QC issues. AKA China doesn’t need to learn how to cast iron properly ;) |
238 days ago |
Yeah, cast iron you’ve got to cast, let age a while, then machine, if you don’t, that’s when it warps. Didn’t know the problem was that wide spread now, but I can understand. Haven’t run into that myself. Ok, so it appears it’s for the manufacturers benefit and not necessarily ours, and they’re trying to convince us it’s better, I suspected that. I’m not implying it’s not, I don’t know, but I don’t want it. At least not at this time. -- -Curt, Milwaukee, WI |
238 days ago |
Like a new car model, don’t buy any new concepts till they’ve proven themselves. -- Paul, La Center, Washington |
238 days ago |
Here is the other topic where this subject has been discussed before. |
238 days ago |
A granite top for a piece of machinery is just like any other material – if it is not made to rigid specifications it is worthless. You should look very closely at the top surface of any woodworking machine to make certain that all the channels are milled to exact tolerances. I have seen tops of some table saws where the miter gauge slot was so sloppy the it would have been next to impossible to get accurate cuts. -- Those that say it can't be done should not interrupt those who are doing it. |
238 days ago |
Thanks bentlyj, read the thread, realized after I started this thread I should have searched, my bad. People seem to have a fear of cast iron warping, I guess I would too if it had happened to me. But, correct me if I’m wrong, if something cast iron is going to warp it’s going to warp relatively fast, like within the first year, if not before you even get it, not five, ten years down the road? That being the case, I would think the warranty covers it. I also realized that part of the reason I don’t have rust problems may be because I use Bostik Top-Cote on my Unisaw and DJ-20 (got a free can of it with my Unisaw and quickly discover it really works). But I don’tt (haven’t) used it on the cast iron table on my Jet spindle sander nor on my 12” Delta disk sander and I’ve not experienced rust on either. I also looked up some climatic data on where I live and the annual average humidity is said to be 80%. I compared that with the places that people have said they live in high humidity areas and have rust problems and found their’s to be at a 90% average. So my location isn’t too far off that but that 10% may just be enough to push it over the edge. -- -Curt, Milwaukee, WI |
235 days ago |
Granite in NOT “full” of uranium. I don’t know where that came from. It is a semi-porous natural stone that MAY have some radon traces. If this were not true, what do you think all the granite owners (countertops) would do about the issue? |
235 days ago |
I buy into it as a selling tool as much as I believe that a plastic jobsite saw is worth $800. NOT ! |
219 days ago |
I work in a granite shop doing counter tops for a living and also have a MFA from the University of Montevallo with a concentration in sculpture. So I have cut, ground, and sanded just about every stone you can think of. As far as Uranium I think you would be more likely to get lead poisoning from a pencil(FYI-pencils have graphite in them, so don’t worry!) But kidney stones maybe a problem if you are cutting marble on a regular(calcium). -- Wood,clay,metal, and stone are all just materials, until an artist's hand touches them.--TreeFormDesign |
218 days ago |
There seems to be benefits to both materialsm, but ganite is not a common material to us woodworkers which can make it a bit iffy. -- Let there be sawdust |
218 days ago |
I think the cast iron is more functional, the granite tops I’ve seen look absolutely beautiful though. I don’t have much experience there, though, but thought I’d pitch in my two cents.. |
207 days ago |
If table saws always came with granite tops would people have the same reaction to new fangled cast iron versions;) I don’t have any experience with granite tops but this seems like a six of one/half a dozen of another argument. |
207 days ago |
As a 20 + year woodworker I’ve never meet any one with a warped table saw top and have only seen a couple with real rust problems and they had been stored out side. as for throwing your table saw top across the room I’d like to see that granite or cast iron as long as I don’t have to catch. I’m with Pat I like those magnetic feather boards and the make my sawing much safer. One item another LJer had heard at woodcraft is they were not going to carry steel city because they were about to fold. and the review of the Ridgid under reviews said that the granite tops on display had there corners missing and the reviewer said there table should be returned. So maybe I’m like the guy that said those horseless carriage things will never last but I know what has worked for me. -- Jim from Heirloom Woodshop Southern Oregon |
195 days ago |
Surface plates are intended to provide a very flat working surface, with excellent dimensional stability, i.e. minimal expansion/contraction/warpage due to temperature variations. If ground flat, they tend to remain that way. Nevertheless, I’d recommend using the frame/stand designed to support the plate. This provides the best opportunity for it to remain flat without introducing any bending forces. If they are excessive, rock breaks. The benefits of granite have been stated in numerous responses, namely very slick surface, freedom from humidity effects, and heavy enough to assure “rock solid” usage. Drawbacks include chipping/breaking, depending on how hard they are hit. Also, don’t do anything that causes localized heating such as welding. Use carefully, and enjoy for a lifetime, but remember they are NOT indestructible. |
195 days ago |
Got to go with Jim on this one… I do not own any granite top tools, and probably will not any time soon, does that mean I think they are bad ??? No, does that mean I will never own any granite top tools ? No, but like the old saying goes, “If it ain’t broke, don’t fix it” . Another poster said a few replies ago…”Never buy the new model car untill they work ot the bugs”. I am sure the granite has some fine points to it…and if I ever decide to drop a bunch of money to upgrade my shop again….I would probably look at granite top tools. But hopefully that will be YEARS down the road…and by then all the bugs if they even have an…will be worked out. -- Don S.E. OK |
194 days ago |
Looks like I will be the guinea pig here. I recently bought the Ridgid granite top table saw, upgrading from a 20yr old craftsman electronic TS with cast top. At $450 the cabinet hybrid was not too expensive a gamble for me to take, and the mobility and cabinet design fits my shop needs. My use is for occasional ripping on home DIY projects, since I have a radial arm that I use for cross cutting. As far as durability, chipping, etc. I’ll let you know, but the top and wings are much thicker than the granite tops in my kitchen and after seeing how durable those have been through everyday use for years, I think I will get a good return out of the money spent on it. I will miss the digital motorized blade settings on the Craftsman, as that was a nice feature. |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
