| Forum topic by Zuki | posted 924 days ago | 1731 views | 0 times favorited | 9 replies | ![]() |
924 days ago |
This is the first time that I have attempted jointing. I do not have a jointer, but instead have a table mounted router. This is where I found the information on how to joint with a router http://www.woodshopdemos.com/rtrplnr.htm I added 1/16” to the left side of the fence. I tried this on a couple of boards (8” wide, 8” long, 13/16 thick) and sure enough, after a couple of passes the edge of the board was at a 90 degree to the face and smooth as a baby’s bottom. After doing a couple of boards I decided to put 2 jointed edges together. Well much to my surprise there was a slight crown (bow) in the center of the 8’ boards along the joint that would not allow them to fit together flush the full length. Other points: What did I do wrong?? -- The significant problems we face cannot be solved by the same level of thinking that created them |
