How stable will this octagon wrapped in molding be?
Forum topic by PhilosopherSteve posted 01-21-2015 02:00 PM 952 views 0 times favorited 7 replies Add to Favorites Watch
View PhilosopherSteve's profile
PhilosopherSteve
43 posts in 4229 days
01-21-2015 02:00 PM
I wanted to make several of these cipher wheels in hardwood instead of plywood (buyers don’t seem to like hearing “plywood” anymore). These are made from a core of 3/4” thick maple or cherry (the maple one is in the picture) wrapped with 1/2” wide walnut. I do like the nice contrast. These are only about 8” from side to side – that makes the center area 7”. Each edge is just under 3”. The center circle is 3 3/4” diameter and I left some wiggle room for it.
Question is, even on a piece this small, could the molding cause problems or just come right off? In looking at it, I’m even now worried about the hand wheel I glued onto the center – could it keep that from being allowed to move as well.
These are an item I want to sell, so I’m being a little more cautious than if I was keeping it myself (I could always glue a piece back on).
I could still take the molding off, as well as the hand wheel (I think the hand wheel looks kinda chunky anyway). Bandsaw and table saw with a bit of scraping and sanding could remove this.
Am I over worrying or rightfully cautious? Thoughts? Also, do you think the center hand wheel is too chunky?
Thanks, Steve!
7 replies so far
6864 posts in 4123 days
#1 posted 01-21-2015 02:08 PM
Hi Steve;
You may be over doing it, as modern glues have fantastic holding power.
However, if it makes you feel better, add some pin nails. If you have a pin nailer, you’ll find the hole is so small there really is no need to fill them, yet they do provide holding power, when used in conjunction with glue.
View Yonak's profile
Yonak
986 posts in 1664 days
#2 posted 01-21-2015 03:03 PM
...hardwood instead of plywood (buyers don t seem to like hearing “plywood” anymore).
- PhilosopherSteve
Don’t call it plywood. Call it veneer constructed.
View MrFid's profile
MrFid
884 posts in 2048 days
#3 posted 01-21-2015 03:14 PM
Don t call it plywood. Call it veneer core.
- Yonak
Hah! I wouldn’t worry about it. Larger projects will have more stretching and shrinking than smaller projects. Could you maybe do some decorative turning for the center handwheel? That might make it look a little more elegant, if you’re looking for suggestions. Not sure if you have access to a lathe or not.
-- Bailey F - Eastern Mass.
View bondogaposis's profile
bondogaposis
4986 posts in 2495 days
#4 posted 01-21-2015 03:26 PM
Since the plywood is stable and the trim pieces will not move in length, you will be fine. The center wheel may cause a problem in the long run. I would just apply glue to the very center of it and then it will be free to move independent of the plywood.
-- Bondo Gaposis
PhilosopherSteve
#5 posted 01-22-2015 04:12 PM
Thanks for all the great replies. While it seems that I am probably over worrying – I may still take one of the wheels I made I remove the edging and see what other kind of adornment I can put on. In looking around it seems even a piece this size could move about 1/16” or so. While those joints will probably hold, I don’t mind a little challenge to see what other possibilities I have. I do have a lathe to maybe play with those hand wheels.
Lee – good idea on a few pin nails. They can solve a variety of problems.
Yonak/MrFid – veneer constructed/core – love it. I will have to use that!
Bondogaposis – These wheels don’t use plywood which is why I was worried. With the tip on “veneer core” I will probably go back to plys for the stability.
16276 posts in 4362 days
#6 posted 01-22-2015 04:22 PM
One more vote for “don’t worry about it.” I’ve never had wood movement cause a problem on any of the many, many small boxes I have made.
View Ghidrah's profile
Ghidrah
667 posts in 1366 days
#7 posted 01-24-2015 01:23 AM
If the wood has been aged well and the moisture content is low enough when you seal it with whatever you use there’ll be minimum expansion/contraction. If you dado the trim into the oct and give it a smidge wiggle room, (like a breadboard end) all you have to do is pin nail the middle of one face. The oct can move as much as it wants.
-- I meant to do that!
