Fix for bandsaw blade rubbing on return blade guard?
Forum topic by mercwear posted 01-21-2015 02:06 AM 2878 views 0 times favorited 15 replies Add to Favorites Watch
View mercwear's profile
mercwear
30 posts in 1461 days
01-21-2015 02:06 AM
With the help of this forum I was able to fix the tension issues my new (used) bandsaw was having. I have hit another wall that I could use some advice on. The blade is now rubbing against the return blade guard once I have applied tension to it. I have spent a while adjusting the tracking / tension with no luck.
Here is a video of what I am talking about, the first few seconds show the blade rubbing as it comes off the bottom wheel and the end of the video shows the blade passing though the guard with no problem as it exits the guard and goes onto the top wheel: http://youtu.be/lZ-ehGZcdcM
I have a few theories but I am new at this so they probably dont hold water:
1. Blade guard is warped and needs to be replaces (it appears straight so this one is a long shot)
2. I noticed that the upper wheel is slightly more to the left than the lower wheel but I do not see any way to adjust either wheel since the lower one is fixed and the upper one only has a tension and tracking adjustment (no left / right adjustment).
3. I read that the wheels need to be coplanar which they appear to be when I use a straight edge to ensure they are on the same plane.
Thanks again for all of the help.
15 replies so far
View ElChe's profile
ElChe
630 posts in 1574 days
#1 posted 01-21-2015 02:58 AM
Iturra sells a machined hinge for the top wheel that you can shim with included washers to move the top wheel axle left or right thus moving the top wheel left or right. I resd an old article where the author suggested moving the factory hinge left or right by grinding off material from the hinge and then shimming it to move the top wheel. The bottom wheel I don’t think can be moved left or right.
View Picklehead's profile
Picklehead
1053 posts in 2167 days
#2 posted 01-21-2015 03:28 AM
Tom got it right. I remember seeing that in Iturra’s catalog, thinking it was pretty slick.
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
ElChe
#3 posted 01-21-2015 04:14 AM
You can take a look at the Iturra catalog here. The machined pivot hinge that holds the wheel shaft is described. I’m not sure if it will fit a Jet. You’d have to call Iturra.
http://idvwdesign.blogspot.com/2012/05/download-iturra-designs-2010-catalog.html
View MrUnix's profile
MrUnix
7106 posts in 2437 days
#4 posted 01-21-2015 04:49 AM
Or just shim the bottom of the blade guard so it doesn’t rub.. shouldn’t be too hard (or expensive).
View jumbojack's profile
jumbojack
1685 posts in 2862 days
#5 posted 01-21-2015 05:10 AM
Inside the mounting housing for the blade guard there shout be a screw that attaches the guard to the saw frame. It is slightly adjustable. Shine a light in there, you should see it.
mercwear
#6 posted 01-21-2015 02:09 PM
- jumbojack
Thanks. I adjusted these to pull the guard as far right as it will go but the blade is still rubbing. Does anyone have an idea of what causes the blade to rub in the first place? I can shim the guard but I am more interested in fixing the root of the problem rather than adjusting my saw to compensate for it.
Thanks
mercwear
#7 posted 01-21-2015 02:22 PM
You can take a look at the Iturra catalog here. The machined pivot hinge that holds the wheel shaft is described. I m not sure if it will fit a Jet. You d have to call Iturra.
- ElChe
The catalog link on that site is no longer working. I need to order some bearings for the saw anyway so I’ll just call him and get a catalog with the order. Thanks!
View bdresch's profile
bdresch
151 posts in 1846 days
#8 posted 01-21-2015 06:29 PM
I had the same problem on mine but in the other direction. I just took it over to the oscillating spindle sander and opened up the hole in the hole in the plastic to allow it to shift over.
jumbojack
#9 posted 01-22-2015 01:04 AM
I certainly would NOT start messing with the wheels. I still think something is amiss with the mounting of the guard. With the blade off does the lower wheel have any play?
jumbojack
#10 posted 01-22-2015 01:51 AM
Please forgive me in advance, but do you have tires on your wheels.
mercwear
#11 posted 01-22-2015 01:55 AM
- jumbojack
You are forgiven and thank you for not making any assumptions :) The tires on my wheels both look great!
mercwear
#12 posted 01-22-2015 01:58 AM
- jumbojack
You are spot on. I fine tuned the bolts holding the guard to the frame like bdresch and you suggested, that fixed the problem :)
jumbojack
#13 posted 01-22-2015 02:47 AM
My heart soars.
Now, I have two words for you. Alex Snodgrass. Look him up on YouTube. You will not be sorry.
mercwear
#14 posted 01-22-2015 02:54 AM
My heart soars.
- jumbojack
I have watched his clinic about 3 times now. Very good information.
View woodworkerdoug's profile
woodworkerdoug
1 post in 680 days
#15 posted 03-11-2017 12:46 AM
I believe the problem is the bolt in the bottom of the left blade guard is skewing the blade guard into the blade. Your video shows an improper installation of the blade guard. There is a rectangular washer that centers the screw for the proper orientation of the blade guard. See photo. You are not using it. I happen to be looking for that same washer and came across your post. The washer registers either side of the raised registrations on the blade guard, centering the blade guard. Sorry I’m a couple of years late. I recently have gotten around this by threading a screw through a t-nut using a rubber washer, a t-nut reversed and some washers next to top of screw. see photo. The rubber washer from the hardware store keeps the t-nut from slipping on the blade guard. I am searching for the rectangular washers even though what I have done seems to work fine. The t-nut has the advantage over round washers in that it is a tight fit where washers are loose.
Hope this helps someone.
