lathe jig for the drill press
Forum topic by martin007 posted 04-01-2009 03:17 PM 2518 views 0 times favorited 10 replies Add to Favorites Watch
View martin007's profile
martin007
142 posts in 4009 days
04-01-2009 03:17 PM
HI
Anybody tried this jig. I am thinking to make one for small turning like knobs and small legs. I Can’t afford a real lathe now but I do have a good floor drill press.
thanks
-- Martin, Gatineau, Québec
10 replies so far
TopamaxSurvivor
18422 posts in 3910 days
#1 posted 04-02-2009 03:50 AM
NO, but I have been thinking of doing something like that or making a small wooden lathe to use with a drill motor for small parts.
View PG_Zac's profile
PG_Zac
368 posts in 3623 days
#2 posted 04-02-2009 05:39 PM
That looks really cool Martin. I think I may make one for myself.
Where did you see it?
View marcb's profile
marcb
768 posts in 3907 days
#3 posted 04-02-2009 05:44 PM
I was just envisioning something like that. I need to make a couple handles.
martin007
#4 posted 04-02-2009 05:48 PM
from grizzly
http://grizzly.com/products/H8071
marcb
#5 posted 04-02-2009 05:51 PM
I would make sure your DP can handle the side load. Depending on the bearings you might kill them.
My DP has deep groove bearings. Also unless you have a Morse Taper or a JT 33C you will probably pull the chuck right off the press, and possible gall the JT.
View hairy's profile
hairy
2783 posts in 3766 days
#6 posted 04-02-2009 11:20 PM
It might work for sanding, but I’d rather not try to do any real cutting. Just my opinion.
-- My reality check bounced...
View swirt's profile
swirt
3546 posts in 3206 days
#7 posted 07-18-2010 05:29 AM
Martin007, I know it has been over a year since you posted this. Did you try this out? I’m looking for something to help me shape and sand tool handles once in a while. The $20 price tag is appealing.
...Or if anyone else has used this, your thoughts would be appreciated.
View MrRon's profile
MrRon
5258 posts in 3477 days
#8 posted 07-18-2010 11:14 PM
I’m dubious about using any tool for a job it wasn’t intended for. You could end up ruining the bearings.
View dedalo's profile
dedalo
173 posts in 3131 days
#9 posted 07-19-2010 12:34 AM
couldn’t be dangerous?
-- http://carpinteriaenargentina.blogspot.com
View bent's profile
bent
311 posts in 3903 days
#10 posted 07-19-2010 12:52 AM
the tool rest seems sketchy to me. it looks like it would take alot more effort from the user to counterbalance the cutting force. i could see that resulting in more tool chatter or catching. i think hairy has it right.
