Ramped Shooting board: Is it necessary?
« back to Hand Tools forum
Forum topic by handsawgeek posted 01-20-2015 08:41 PM 1808 views 0 times favorited 10 replies Add to Favorites Watch
View handsawgeek's profile
handsawgeek
645 posts in 1391 days
01-20-2015 08:41 PM
Hi, All,
I’m planning on building a shooting board in the next couple of weeks, and I have to ask the million dollar question: Is a ramped guide board necessary, or does a flat guide board work just fine?
I’ve read a number of conflicting opinions about this subject. Some argue that a flat guide board will wear the plane sole down over time. Others say ‘no worries’. Let the discussion begin…..
-- Ed
10 replies so far
Gerald Thompson
935 posts in 2230 days
#1 posted 01-20-2015 10:41 PM
A flat board would take several life times to wear out a plane sole IMHO. Some of the reasons I have read, (1) The plane iron acts as a skewed edge and can cut gnarly wood better. (2) The plane iron wears more evenly. If one were shooting a consistent width of board(s) for a good while that area of the iron would dull and one would have to take it out and hone it more often.
I have all flat boards because I am too lazy to make a ramped ones.
-- Jerry
View JohnChung's profile
JohnChung
408 posts in 2070 days
#2 posted 01-21-2015 12:48 PM
It is not necessary BUT will help a lot. Here is my post:
http://lumberjocks.com/topics/58912
handsawgeek
#3 posted 01-22-2015 02:13 PM
Thanks for the replies.
I think I will have to decide which method I wish to go based on available time. I’ve seen some ‘ramped’ boards where the ramp is hand planed into the guide board. Johnchung, I like your version with the guide held up by wedges. Jerry, a ‘no ramp’ version looks viable, too. Plane soles can easily be re-flattened, and irons can be sharpened (once in a while). Decisions, decisions.
Anyway, thanks again!
-- Ed
Smitty_Cabinetshop
15348 posts in 2614 days
#4 posted 01-22-2015 03:23 PM
The reasoning behind a ramped shooter has never included ‘sole wear’ that I’ve ever seen. Jerry said it: That’s bogus. A skewed iron goes cross-grain with less tear out, and a shooter on a skew -or ramp- does cut end grain better. My input is based on owning and using shootboard planes with and without skewed cutters.
handsawgeek
#5 posted 01-22-2015 04:30 PM
Thanks Smitty,
That settles it..it’s a skewed ramp for me!
-- Ed
View sikrap's profile
sikrap
1121 posts in 3355 days
#6 posted 01-24-2015 03:29 PM
Late to the party, but if you’re using a Veritas shooting plane, the ramped board isn’t necessary because the blade is already skewed.
-- Dave, Colonie, NY
View waho6o9's profile
waho6o9
8189 posts in 2573 days
#7 posted 01-24-2015 05:02 PM
I think a skewed ramp works better, at least for me it does.
JohnChung
#8 posted 01-24-2015 05:26 PM
The Veritas shooting plane works better with a skew board. I have use both designs and the skew is my preferred choice.
handsawgeek
#9 posted 01-26-2015 03:13 PM
Thanks for the further replies. I will definite go with a skewed ramp. I will likely be starting out with a regular #5 jack plane until I can spring for a low angle version or even the Veritas.
-- Ed
View Derek Cohen's profile
Derek Cohen
370 posts in 3964 days
#10 posted 02-01-2015 01:40 AM
The advantage of a ramped shooting board is that it enables a plane with a squared blade to enter the wood at at slight angle (skew) – not for a skew cut, but a progressive cut at entry. What this does is reduce the impact shock, which makes planing easier and more pleasant. There is also some spread of wear on the blade, but I do not consider this to be particularly significant.
Now if you have a plane with a skeewed blade, such as a Veritas or Lie-nielsen #51, then the impact issue is a feature of this blade, and a simple flat board is all that is needed. Indeed, the ramped board will reduce the skew of the blade by 5 degrees – not particularly significant in use, however, but still a fact.
Here is one of several articles I have written: http://www.inthewoodshop.com/ToolReviews/LVShootingPlane.html
Another: http://www.inthewoodshop.com/Furniture/ShootingPlanesCompared.html
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
