| Forum topic by parkerdude | posted 246 days ago | 393 views | 0 times favorited | 11 replies | ![]() |
246 days ago |
Topic tags/keywords: radial arm saw The title kind of sums it up. I’ve got an old Craftsman RA saw that’s in very good shape and is my primary power saw, (I’m mostly a hand tool guy). I’m making several utility cabinets from birch plywood and I’d like to edge band all of the exposed edges for durability. Does anyone have a safe solution to rip 1/4 X 3/4” thin strips? Thanks for your help everyone, I like this forum. parkerdude -- dust control |
246 days ago |
Have you thought about ironing on birch edge banding tape? That would be the safest. Not as durable, but safe. |
245 days ago |
I only tried to rip once on a RA saw, and it will be the last time I will try that again. Let alone trying to rip thin strips. Some lumber yards sell 1/4×3/4 stock, I would look for that. |
245 days ago |
Or – do you have a buddy with a TS? -- Joe |
245 days ago |
A roll of edge banding costs less than $10. Well worth the cost of trying and probably not succeeding with using the RAS for cutting small stock that size. -- Respect your shop tools and they will respect you - Ric |
245 days ago |
Parkerdude, The problem with using the RAS for this type of cut is the usable bit ends up between the blade and the fence or you spend a lot of time relocating the trolly. The easiest way to do this on a RAS, to quote ‘mater from CARS is “to not to”. ;) Where are you located? Maybe there’s a ‘jock near you with a table saw. Whit -- Even if to be nothing more than a bad example, everything serves a purpose. |
244 days ago |
I’m not very smart. I have tried to rip on my RAS. Lee -- No piece is cut too short. It was meant for a smaller project. |
244 days ago |
First you will need a blade meant for the RAS. Second you will need a few holddowns. Once the holdowns are set up so the blade does not grab and lift the wood you can slowly feed it thru with a long scrap block. I feed mine from the left side of the machine. |
243 days ago |
i think rocker has thicker edgebanding that you can order. but if i were you id just find a buddy with a table saw or your local lumberyard might have a tablesaw which they would rip a few strips for you |
243 days ago |
Just two days ago I was giving a Sears 10” radial arm saw. In Excellant shape. A friend gave it to him. He has had a high end cabinet shop for at least 25+ years. He has one in his shop already. His words were this saw is free to you if “YOU LOCK IT AT 90 or 45 DEGRESS AND DON’T USE IT ANY OTHER WAY NO MATER WHAT ANY BOOK SAY’S TO USE IT ANY OTHER WAY” Every piece of equipment has its purpose and that is the purpose for that saw. A long stroke cut off. Period. I have not used it yet but thought I would pass on the advise I was given. LOL, Dino -- DBC,Dino, Designer, Cad Draftstman,Builder/Finishcarptenr-Bass Guitar Builder/Player. |
243 days ago |
Plenty of people out there use a RAS for ripping. It can be done and done safely. But the RAS needs to be adjusted well in all directions. The unit also needs to have the safety devices installed, antikickback pawls etc. |
243 days ago |
Marcb: I believe you are correct ! My advisor new I do not have experience with a RAS and was only thinking of my safety with a tool that can cause great person harm. As can most of the tools of this Hobby/Profession. I apologize to all if I spoke out of line, Dino -- DBC,Dino, Designer, Cad Draftstman,Builder/Finishcarptenr-Bass Guitar Builder/Player. |
| Forum | Topics |
Woodworking Skill Share
2937 |
3968 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
